  #11 (permalink)
Old 12-03-2005, 09:13 AM
01stroker 01stroker is offline
I use Rotella T 15-40 and wix filters. perfect combo
  #12 (permalink)
Old 12-04-2005, 03:55 PM
tdi jerry tdi jerry is offline
Thumbs up mobil truck & suv
mobil 1 truck and suv is a great oil its a syt.at work we use mobil delvac 15w40 in all of our equiment at weyerhaeuser here in north carolina.
  #13 (permalink)
Old 12-06-2005, 04:19 PM
your2slow your2slow is offline
Based on the tests I've seen I'll be switching to Schaeffer's 9000 Supreme on my next oil change.
  #14 (permalink)
Old 12-06-2005, 09:44 PM
Mike OB Mike OB is offline
How about showing us theos test results??? Mike OB
  #15 (permalink)
Old 12-07-2005, 05:28 AM
Check out Bobistheoilguy.com. You'll find alot of information out about Schaeffer's Oil as well as most any other oil on the market. I know Schaeffer's is a sponsor there, but so is Amsoil and some others.
Here's a link to the Schaeffer's technical data for 9000 Supreme:
http://www.schaefferoil.com/datapdf/9000.pdf
  #16 (permalink)
Old 05-28-2006, 08:31 AM
fyreles fyreles is offline
oil
I have had great luck over the years with Rotella synthetic blend, not just with this diesel, but with my 95 which I slod with 224,000 miles on it and running strong. Also I ahve used synthetic fuel stabilizer on occaision when I have a couple of extra bucks in my pocket. les
  #17 (permalink)
Old 05-28-2006, 10:12 AM
whttrk whttrk is offline
Has anyone used Castrol Tection? I have used Castrol in my cars and motorcycles for years and when I got into my Honda 500 cc for an alternator/generator replacement at 80,000 miles the aluminum innards were as clean and shiny as the outsides, and the cars have never needed any teardown. My '82 diesel Rabbit got run into at 270,000 miles and always had Castrol GTX. That's my testimonial for Castrol, and would like to use their diesel product if someone else has tried it and likes it.
  #18 (permalink)
Old 05-28-2006, 11:11 AM
Brian Brian is offline
Originally Posted by Trailrider217
I just recently bought a 99 ford f350 with a 7.3 powerstroke and it is about time for a oil change. The engine has a little over 90 k miles and I dont know what was used in it before ? I have deisel tractors and generators on my farm and I use rotella t in them I use castroll in all my gas engins . What does ford recomend advise needed thatks Steve
i personally would stick to rotella.
i dont mind changing my oil every 3-5k. gives me a chance to get a good look at the bottom side (ie. looking for leaks, worn parts, and ect.)
  #19 (permalink)
Old 05-28-2006, 08:19 PM
Lone Ranger Lone Ranger is offline
In all fairness, Rotella, Mobil, Castrol, Motorcraft, they are all good oils. I used to swear by Delvac in the Marine engines is severe hard going... But the truth is they are probably all good enough. Ford Australia is saying Castrol RX Super, even Castrol Tection Plus... In all fairness, I would not worry about which one I used anywhere near as much as HOW OFTEN I CHANGED IT!!!! :burnout
Severe work, like here in Oz, towing? Or severe work like in running big chips and street drags? I would change the oil closer to 3500 miles, and then I do not think it matters which of the good choices above... 5000 km here in Oz, not the Factory listed 7500 or the Factory listed 5000 miles. If it is hard going, change it more frequently, then the oil choice is not much to talk about of the above ones..
Regards from the Lone Ranger, changing oil since the 60's... Ha!
