What is the average cost to install 2" coil spacers? - Ford Powerstroke Diesel Forum
Old 10-06-2009, 10:56 AM
Was wondering what the average cost to install 2" coil spacers on a '99 f250 2WD is? I was quoted $260 and I supply the spacers. Is that about the average price?
Old 10-06-2009, 01:24 PM
That sounds about right. This may be something you could tackle in your driveway too... I don't think it would be too hard.
Old 10-06-2009, 04:13 PM
That's what I thought but I'm getting some front end work done right now and the alignment getting done so I figured it would be a good time. I really don't have the time to do it myself either. If $260 sounds about right then I'll probably just have it done. Thanks for the help.
Old 10-07-2009, 05:29 AM
I bought the spacers and put them on myself over the weekend (only took about 2 hours) and was planning on getting the tires realigned once finished. I took it to the local shop here (i know the owner) and they ended up having to install camber plates because the spacers through the alignment off so bad and it cost $218 for the camper plates install and alignment. Just thought id give you the warning so your not looking at another $200 after you get your spacers installed. by the way i have a 99 2wd f350.
