Mountable...
Hey there yall, I was just wondering if the intercooler an tranny cooler from an 07 will mount up to my 02, without to much hassle? Cause i have seen a few guys on the ORG with 6.0 intercoolers, or is that maybe just until 04 when they switched the front end around? Any help would be great, Thanks...
Yes you want the tranny cooler. It isn't too hard to install. Just some 1/2" tranny line along with some 3/8" to 1/2" barbed adapter fittings.
The intercooler should work too... but you will need to get an adapter boot for one intercooler tube. |
Perfect so the tranny cooler is a direct fit from the 07 to 02 or do i need to get new adapter fittings? Also the intercooler will bolt up using the original mountment of the 02 intercooler? Thanks for all your help man...
You will need some adapter fittings specifically 3/8" to 1/2" barbed fittings and several feet of 1/2" tranny line.
The one thing you might do a search on is the 6.0 intercooler and the 6.0 tranny cooler together... I have read somewhere that they might conflict a little bit in the older trucks. That tranny cooler is huge compared to the 7.3 stocker. With the combo of the bigger 6.0 intercooler and the taller tranny cooler they might have some issues. See if you can find it in a search or someone might post up. But I do know you can get them both in there...
Thank you very much for all the info, an i am looking around to try an find a thread about the intercooler an tranny cooler swop... The 6.0 tranny cooler bolts right in an all i have to do is get thoughs adapter fittings, right? Thanks again man...
yea the 6.0 trans cooler is a direct bolt in
i'm pretty sure the intercooler bolts in fine too just different boots |
Perfect i real hope so... Even if its an 07 right, or is it possable that it might differ when the front end changed in 05?
nope.. don't worry it will all fit in there somehow
Alright now all i have to do is try an find the right transition boot for it an then i will have myself a project... Thanks all...
lots of places sell the right boots
dieselsite.com is the first one that comes to mind since i was on there last night |
