No instruments, truck won't start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-05-2009, 08:31 AM Thread Starter
No instruments or gauges or tach when cranking, truck won't start. Worked fine yesterday, this AM, kaput. 2003 F350 7.3 6 Spd CC Long Bed. Checked fuses under dash, all OK. Noticed that after key is turned on, after a few seconds there is a brief sound coming from engine bay on drivers side and somewhere below battery box. Other devices like radio, blower, interior lites, day time running lites, signal lites work. All advice appreciated. Thanks
ag-lad is offline
post #2 of 6 Old 10-05-2009, 10:32 AM
Powerstroke Junkie
NCHornet's Avatar
No WTS light or other dash lights is a sure sign of PCM failure. I would make sure fuse #30 is not blown too. If it is check your fuel bowl heater.
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #3 of 6 Old 10-05-2009, 03:38 PM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Mine did something similar, turned out to be the connection "post" at the top of the drivers side inner fenderwell where the battery (+) wire went to two fuseable links.
Easy to check, just look down in back of the airbox at the top of the well for a big red wire that goes into a 1X1" box. Pull up the cover and look for "green"
NoRalPh is offline
post #4 of 6 Old 10-05-2009, 04:45 PM Thread Starter
Problem solved. Fuse #301, 30 amp, labeled "Ignition Switch" was blown. This fuse supplies power to Fuel Bowl Heater; which have been known to short and/or cause problems. Disconnected heater and all is now good. I live in Saskatchewan where the temperature can drop to minus 40, so I'm wondering if not having the heater is going to be an issue when the cold sets in. Thanks for the replies. This one was a cheap fix.
ag-lad is offline
post #5 of 6 Old 10-06-2009, 05:59 AM
superduty4x4's Avatar
You should be fine without the fuel bowl heater, glad you found the problem.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #6 of 6 Old 10-06-2009, 06:10 AM
Powerstroke Junkie
NCHornet's Avatar
Sounds like something I wrote, lol!!! Glad you found the problem!!
NCH
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
