Help towing
First time to pull with the 7.3 and was very disappointed. I had my 4wheeler loaded on my 16ft. trailer with cooler and ice and could not not pull a hill for nothing. Where should I try to keep my rpm's? I know it has more power than this, I did just install a 4'' TB and S&B CAI which help a whole lot but still. Those that tow often with their 7.3 help.
I ust to do a lot of towing, but just pulling my 4wheeler i'd hardly feel it back there.
Yeah that's not normal. Have the fuel filters been changed recently?
Do you know what your boost and EGTs are?
Do you have a fresh fuel filter? I pull a 12k 5er and can pull a med hill at 70 mph and 2100 rpm pretty easy. When I pull my boat (about 4k) I hardly know its there. Something is not right with your truck. |
I just bought it so it has new oil and filters through out the truck. I didnt push it to hard but in overdrive it would be at about 1600 rpms, I had to really get into the fuel just to downshift so it would keep its speed. I wouldnt think it would have a problem pulling that small of a load in overdrive?
did you check to see if the filters were changed or did you just take thier word for it??? if they are new i would check fuel pressure, and you screens might be plugged inside the fuel tank... with my 02 i can pull my 25K horse trailer all over without any problems...
ohhh do you have stock sized tires on it?? |
Something is wrong!!! A F150 could pull that load with little to no effort. I would get gauges, you should have them anyway, I wonder how much boost you are able to pull? Check your intake boots for holes or tears and make sure the clamps are good n tight. I would also scan with a compatable scanner ( not OBDII ) and check for codes. You can PM if needed.
NCH |
