tranny rebuild - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-04-2009, 08:16 AM Thread Starter
tranny rebuild
does anyone have a list of the parts or a link of the typical parts replaced in an automatic transmission rebuild?
also since our trannys are obviously pieces of ****...which parts are the most important to upgrade to sustain more power and longer life?
trying not to break the bank here
2002 F350 Crew Cab 4x4
7.3L Automatic
aFe Magnum Flow Intake
Magnaflow 4" Exhaust
Western Diesel A-pillar cluster
Add-a-leaf in rear
Levelling kit
<--Clicky (my jeep's in the back...it might become a diesel one day too)
SmokeTown is offline
post #2 of 13 Old 10-04-2009, 09:04 AM
Tony V's Avatar
Uh im not real sure, but i'd say a good transmission shop would know. If your not going for a lot of power just buy the suncoast rebuild and a good TC and good VB you'd be set.
2000 F-250 216k- smoke much?
Facebook: Anthony VanCamp
Add me if you'd like
Tony V is offline
post #3 of 13 Old 10-04-2009, 09:12 AM
Other vehicle is an F250
Hank's Avatar
The guy that built mine keeps telling me he'll give me a list but never has. These guys like to keep their "secrets" close. Torque converter is the weakest link. Get a better than good one. I have one that supposedly is used in F550-650 power company line trucks. 13000-14000 miles so far and doing well. Before, this one the truck killed three FORD remanufactured ones. In fact, I still had warranty left and gave it up to get one that wouldn't leave me stranded. My builder told me that the FORD remanufactured one wasn't even assembled correctly. I don't know, but I expect these are built by "the low bidder" and you know how that can be sometimes?
Find someone that pulls sleds or drag races their truck and ask who built their tranny. That's what I did. Worked out so far.
Good luck!
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #4 of 13 Old 10-04-2009, 11:26 AM
Tony V's Avatar
Well im getting a BTS trans and they are known for pulling trucks.
Tony V is offline
post #5 of 13 Old 10-04-2009, 12:19 PM Thread Starter
ok well here's the thing...my job pays for schooling so i decided to go to lincoln tech for auto technician. and they told me that during the transmission section of the course you can work on and rebuild your own transmission if you want instead of one of the ones they provide for you. so buying a new or rebuilt one is out of the question...and i'm sure i'll know all of the parts needed by the time i get to that stage...so mostly i want to know what needs to be replaced...so stuff like hank said "torque converter is weakest link" ...good info for me. thanks...anything else that's damn near mandatory for 350+hp? i'm not at those numbers yet obviously, but i will be.
7.3L Automatic
Add-a-leaf in rear
Levelling kit
post #6 of 13 Old 10-04-2009, 12:27 PM
Tony V's Avatar
you will want a valve body as well. I was looking into a suncoast rebuild that comes with all the stuff you'd need for the inside im pretty sure.
Tony V is offline
post #7 of 13 Old 10-04-2009, 03:35 PM
are torque converters are bad about balloning up and destroying the pump, also the single clutch is really a weak setup for these massive trucks, stock planetaries will grenade with stock power, upgrade the input shaft and valve body if anything over stock
2000 F-350 Crewcab DW 2wd Auto
-Engine: DIY Intake, Straight pipe exhuast
-Transmission: Triple clutch billet converter, 6 gear steel planetaries, 31 row 6.0 cooler, tci deep pan
-Auto meter Tripod Gauge kit
-Truck use: Grocery getter, hauling play tows
dmc919 is offline
post #8 of 13 Old 10-04-2009, 03:52 PM
BIGBILL105 45's Avatar
My torque converter shredded and went threw my pump and the pump pumped the pieces through out the whole transmission and destroyed it all.
PM ME FOR VINYL DECALS!
SOLD!!!!!
ARP head studs
4 inch down pipe
5 inch straight pipe
ts 6 pos chip
foil delete w/ polished IC pipes
ugly step delete
2% tint
black lariat rims
35 inch Pro Comp Xterrains
7 inch in dash dvd player
remote starter
16.265
BIGBILL105 45 is offline
post #9 of 13 Old 10-05-2009, 01:26 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
If you want to DYI then only one expert has a kit..John Wood.
CT Performance, Inc. is offline
post #10 of 13 Old 10-06-2009, 03:08 PM Thread Starter
jesus every part is expensive... standard rebuild kit is $500... accumulator body is $350...ats input shaft is $450...torque converters run from $900-$1300...so we're talkin $2,500 for me to do it myself and still not upgrade everything!!...
first thing...the rebuild kit is basically a **** load of seals...just seals...for 500...ripoff
input shaft...no shaft should cost $450...
anyone have nay advice or ways to save on some of these parts? maybe cheaper websites or something
7.3L Automatic
Add-a-leaf in rear
Levelling kit
