Waterpump? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-03-2009, 01:42 PM Thread Starter
deere4440's Avatar
Waterpump?
Ok i noticed my waterpump was leaking, so i got a new one here. But i was wondering about removing the fan. Which way is the nut threaded on there, right hand or left hand threads. Would like to know before i mess something up.
2002 F-350 CC SB 7.3
MBRP 4 in straight pipe
AIS Intake
Foil Delete
Factory Tech Valve Body
203 Thermostat
Fog Light Mod
6k HID's from DDM
TOTALED!! 1/6/2009
2003 F-250, 7.3 FX4
deere4440 is offline
post #2 of 11 Old 10-04-2009, 04:15 AM Thread Starter
deere4440's Avatar
Anybody?
AIS Intake
Foil Delete
203 Thermostat
Fog Light Mod
6k HID's from DDM
TOTALED!! 1/6/2009
2003 F-250, 7.3 FX4
post #3 of 11 Old 10-04-2009, 04:47 AM
Shaking the Bush Boss
CHUCK's Avatar
Should be left hand thread. If you dont have the Ford fan wrenchs....gonna have to use a BIG wrench, or a big adjustable to put on the fan hub/nut itself, and hold the fan pully in place....wedge a big screw driver aganist it. Good Luck. There not the easiest to break loose.
Chuck
CHUCK is offline
post #4 of 11 Old 10-04-2009, 04:55 AM Thread Starter
deere4440's Avatar
Ok thanks, i didn't want to strip out the threads and be screwed. Now i just need to find the coolant i want, and time to do it.
AIS Intake
Foil Delete
203 Thermostat
Fog Light Mod
6k HID's from DDM
TOTALED!! 1/6/2009
2003 F-250, 7.3 FX4
post #5 of 11 Old 10-04-2009, 07:14 AM
Powerstroke Junkie
NCHornet's Avatar
Another trick is to use a air chisel, and hit the edge of the nut on the down stroke and she will spin right off. BTW Most auto stores will loan you the tools for FREE or a small fee.
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #6 of 11 Old 10-04-2009, 08:34 AM
The fan nut is a 1 7/8" and the fan is left handed thread.
99.5 F250
Airaid intake
4" Turbo back, straight
6" lift with 37" BFGs
Boost, Trans, EGT Gauges
Tirepaq
AIH delete
DP Tuner 40/80/120/140 with Gauge Switch
6.0 Intercooler
Foil Delete
Whicked Wheel
Billet T/C
Brand new Tranny
Zoodad Mod
6.0 trans cooler with 2 fan controlled coolers.
KCM S.S. HPX Line
Snow Performance stage 3 meth kit
Sinac is offline
post #7 of 11 Old 10-10-2009, 11:09 AM Thread Starter
deere4440's Avatar
Ok now im wondering, which end of the nut is treaded. I guess i'm bascially asking, which way would i turn the nut toward the driver or passenger side of the truck.
AIS Intake
Foil Delete
203 Thermostat
Fog Light Mod
6k HID's from DDM
TOTALED!! 1/6/2009
2003 F-250, 7.3 FX4
post #8 of 11 Old 10-31-2009, 12:21 PM Thread Starter
deere4440's Avatar
AIS Intake
Foil Delete
203 Thermostat
Fog Light Mod
6k HID's from DDM
TOTALED!! 1/6/2009
2003 F-250, 7.3 FX4
post #9 of 11 Old 10-31-2009, 09:53 PM
Lefty loosy... righty tighty...?
99.5 F250
Airaid intake
Tirepaq
AIH delete
6.0 Intercooler
Foil Delete
Whicked Wheel
Billet T/C
Brand new Tranny
Zoodad Mod
KCM S.S. HPX Line
Sinac is offline
post #10 of 11 Old 10-31-2009, 10:01 PM
The nut will stay attached to the fan and +1 for the air chisel. Makes life ten times easier if you do it correctly 2 or 3 quick taps with the gun and it should be loose.
FOR SALE
2000 F-350XLT 6sp ext cab dually
K&N cold air intake
overboost annihilater
GDS fuel spring
Valair clutch
TS chip
4" down 5" back 6" tip
isspro gauges
unplugged wastegate
GTP38R
00forddiesel is offline
