Time to get workin!
ive done alittle research on my truck ever since i found fuel in my radiator.
the truck runs perfect, you would never even notice ![]() from the research and from the good help in my other post ive found i need to replace the injector cups. it apears to me that i will need to remove the heads. my question is,,,should i port these heads while they are off? is it even worth it on a stock short block? the way i look at it is this,,,,lets get the most out of it while im at it. what else would you guys do? |
Are you sure you need to pull the heads? I thought you could pull it off without removing them... Not sure though...
Probably not worth porting the heads if you are sticking with the predator...
