how do i find out which rearend gear i have - Ford Powerstroke Diesel Forum
post #1 of 22 Old 03-03-2007, 06:40 PM Thread Starter
Send a message via AIM to BadF250Boy99
im curious to know my axle ratio without jacking the truck up and marking the drive shaft is there a better way?
ive got a 99 f250 2wd
BadF250Boy99 is offline
post #2 of 22 Old 03-03-2007, 06:47 PM
im fat and ugly
stump0331's Avatar
there should be a code on the sticker inside the drivers door, see if you can look that code up
2004 Excursion
stump0331 is offline
post #3 of 22 Old 03-04-2007, 04:22 AM
USMC - 6017
00f250's Avatar
There should also be a metal tag on the rear end cover, held on by on the the bolts. On the tag it would include 3L73 - 3.73 gears with limited slip. That number in just an example though, it could be 4L10 for 4.10 with limited slip
Dave
2000 F-250 SD 7.3 PS diesel, 4x4 - Gone
00f250 is offline
post #4 of 22 Old 03-04-2007, 04:44 AM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
This might help
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 — 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 — 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 — 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 — 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 — 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 — 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 — 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 — 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW — 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 — 4.30 limited slip, F-450 Chassis Cab
73 — 4.30 non-limited slip, F-450 Chassis Cab
78 — 4.88 non-limited slip, F-450 Chassis Cab
G8 — 4.88 limited slip, F-450 Chassis Cab
75 — 5.38 non-limited slip, F-450 Chassis Cab
G5 — 5.38 limited slip, F-450 Chassis Cab
GW — 4.10 limited slip, F-450 Chassis Cab
98 — 4.88 non-limited slip, F-550 Chassis Cab
K8 — 4.88 limited slip, F-550 Chassis Cab
95 — 5.38 non-limited slip, F-550 Chassis Cab
K5 — 5.38 limited slip, F-550 Chassis Cab
KW — 4.10 limited slip, F-550 Chassis Cab
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #5 of 22 Old 07-10-2007, 01:41 PM
strikeking300's Avatar
what rear end would I have if the axial code is 3L
strikeking300 is offline
post #6 of 22 Old 07-10-2007, 01:59 PM
SgtStroked7.3's Avatar
Send a message via Yahoo to SgtStroked7.3
dam... that sucks i got 3.73s with no limited slip...
2001 F250 SuperDuty 7.3
AutoMeter Gauges, 5" Turbo Back Exhaust, aFe Stage II Intake, XCal 2 With Tadds Tunes,
2" Leveling Lift, Custom Built Transmission, AIH Boost Fitting.
Snow Performance Water/Methanol Injection Coming Soon...
"When the rich wage war, It's the poor that die"
-Unknown
SgtStroked7.3 is offline
post #7 of 22 Old 07-10-2007, 02:01 PM
International Threat
Marty's Avatar
I would bet you have 3.73.
edit - if you have 3L use some water on a papertowel to wipe off the tag and you'll have 3L 73
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #8 of 22 Old 07-10-2007, 02:02 PM
Marty's Avatar
You're not missing anything. The factory L/S is junk.
Buy a Truetrac....
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #9 of 22 Old 08-02-2007, 02:41 PM
Super Kaz's Avatar
Send a message via AIM to Super Kaz
Sorry to dig this up, but mine says "41" and its a dually?
2000 F-350 Ext Cab Dually
"TOW TRUCK"
Mods: AIH Delete, DIY Tymar Intake, Modded IDM, Zoodad, FBD 5" Straight Pipe Exhaust, ITP Overboost Annihilator, 60 HP Mystery Chip
15.4 @ 87 mph On The Evo
...254k, And Still Going
Super Kaz is offline
post #10 of 22 Old 08-02-2007, 02:43 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
is that on the door tag or on the axle itself kaz
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
