Seafoam in a 7.3? - Page 4 - Ford Powerstroke Diesel Forum
View Poll Results: seafoam in 7.3 - use it or not?
yes 86 63.70%
no 25 18.52%
use a different brand 9 6.67%
it's all BS 15 11.11%
Voters: 135. You may not vote on this poll
post #31 of 70 Old 10-16-2009, 12:31 PM
I dumped one in this tank shes purrin like a kitten now... or shall i say a lion. anyway i love that stuff.
Dietoremain is offline
post #32 of 70 Old 11-04-2009, 08:23 AM
bucwheat's Avatar
Originally Posted by dieseldan2005 View Post
Use it. I am a 100% believer in it. It works when no other treatments will work. I use it in everything from my truck, sleds, wheeler, and boat.
I agree,the fuel sensor in my vette quit and the gauge was all over the place,after a treatment of Seafoam,it fixed it after everything else wouldn't.The gauge in my F-350 Dually did the same thing and Seafoam corrected that also. Great stuff.
1997 F-350 CC Dually
Power Hungry performance chip. DIY air intake ,4" Diamond Eye exhaust, Trans temp gauge,Pyrometer gauge
10,000 Lb. Warn Winch, 1 million candle power auxilary lights,black heavy diamond plate bumper/brushguard
bucwheat is offline
post #33 of 70 Old 11-04-2009, 09:17 AM
I have not used Sea Foam or any other additives with my PSD, but I have used Sea Foam in my boat Mercury outboard 4-stroke fuel injector motor by filling up the fuel filter container with straight Sea Foam. It did not do a thing for that motor despite of a lot of people saying it is great injector cleaner. The fuel injectors had to be removed and sent to a shop using ultrasonic and high pressure cleaning to get them purring again.
I am going to try Sea Foam when I change fuel filter on the PSD to see how it goes with diesel engine.
mas360 is offline
post #34 of 70 Old 11-04-2009, 09:22 AM
jesilvas's Avatar
Quoted: 2 Post(s)
I'll say the best I've ever used was three tank fulls of B20. BUT since this is for Seafoam, I've never used it haha
4R100, 2wd
330,000 + miles
jesilvas is offline
post #35 of 70 Old 11-04-2009, 09:29 AM
Eh sucking up straight seafoam probably isnt good. And yeah it'll be good to your PSD no problems.
post #36 of 70 Old 11-10-2009, 06:43 AM
How often is good practice to run a bottle through the tank, everytime a guy changes the oil, or more frequently? Thanks...
-2002 F350 Lariat
C/C S/B 4x4
-Stage 2 AFE
-Straight Piped
-TS 6 Position Chip
S/75/100/140/HI/AT
-Edge Evolution II
as Gauge Pod
-33/12.5/16
Pro Comp A/T's
-Ultra Rims
-Halo Projector
-Tru Cool Trans Cooler
F350Buster is offline
post #37 of 70 Old 11-10-2009, 08:10 AM
jesilvas's Avatar
Quoted: 2 Post(s)
As much as you want I guess. Every tank. Every other.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #38 of 70 Old 11-10-2009, 09:19 AM
bucwheat's Avatar
My truck has 285,000 miles on it and the fuel gauge just screwed up after all that time ,I would suggest maybe once a year or as needed.
bucwheat is offline
post #39 of 70 Old 11-10-2009, 09:20 AM
There is nothing wrong w/ sucking straight seafoam. It's petrolium and will lube things better than straight diesel being sucked in
85_305 is offline
post #40 of 70 Old 11-10-2009, 11:03 AM
DieselNoob's Avatar
Never have used it. I'm getting ready to due my fuel filter this weekend. So I'll try some in there. So do you just pour the whole thing in the fuel bowl or what?
Alex Bauld
2002 F350 Crew Cab Long Bed
- Napa 6637 Intake
2001 F250 Crew Cab Short Bed
- Stock
1995 Acura Integra GSR
-Way too many mods
1991 Acura Integra LS
- CRVtec Swap
- Built from ground up
DieselNoob is offline
