10mpg wtf! - Ford Powerstroke Diesel Forum
Old 09-29-2009, 02:18 PM
10mpg wtf!
OK like out of no where my milage dropped to like 10. This is with my Edge set to stock and I keep my foot out of it most of the time. Will a fuel filter cause this?
Old 09-29-2009, 02:50 PM
JJR JJR is offline
Yes it will but you would notice a lack of power. Don't know your mileage but worn and dirty injectors can cause this too. Check fuel filter and try adding some Seafoam to your fuel tank.
Old 09-29-2009, 02:52 PM
If you have 4x4 are your hubs locked? Do you feel the truck miss while cruising?
Old 09-29-2009, 05:11 PM
Truck feels fine. Idle is a bit rough. But I think it's always been that way. Still has enough power to smoke the tires. Could a fuel filter cause this? I did add power service to this fillup. I don't know but something has changed. No service engine soon light or anything. I should get better than 10 with no tune and a lite foot rite?
Old 09-29-2009, 06:38 PM
if your not towing i would think you should get atleast 15mpg i think i get about 16 to 18 with my late 99 f250
Old 09-29-2009, 06:43 PM
does it idle rough on cold starts? if so, get a re flash. that will help your mpg's. also check your air filter. a dirty filter will drop mpgs.
Old 09-29-2009, 06:46 PM
can a faulty icp sensor cause this, ive heard this somehwere dont remember tho
Old 09-29-2009, 06:56 PM
I put a diy intake on about 2 weeks ago. It's clean. It runs a bit smoother when it's cold. It also starts faster. Any of this info help any?
