e4od conversion to Torqshift 5R110
has anyone done a conversion froma e4od to a 4r100? i am needing a new tranny and was wanting a 5speed if possible. any info on the conversion would be great. thanks
btw i have a extended cab short bed 4x4 7.3 if it makes any difference Last edited by blainemyers; 09-26-2009 at 10:58 AM. |
4r100 is just an upgraded e4od I was told by my tranny guy. the 4r100 uses the same flywheel as the e40d I noticed while taking out my transmission. I say it should work but I'm not an expert.
I think it will work.
i was not sure if it needed a different computer since it was a 5 speed... ill try to keep looking
It will work. I've got a 03 4r100 in my 96 van. Everything is the same except you'll need to change the park/neutral switch. It's not hard but if you break it it will cost you about$100 to replace it.
The e40d and the 4r100 autos are both 4 speed. |
i am sorry guys i meant to say i wanted to switch my e4od with a Torqshift 5R110. is this swap possible? thanks
That may be a lil more difficult.
With enough money anything is possible. You'd have to get an adapter made to bolt it to the engine and then figure out how to get the electronics for the trans to work. Your looking at (conservatively) $2000-2500 just for that and then add in the trans itself. You could have a built e40d for what it's going to cost and in a fraction of the time.
ok thats all i needed to know. you guys recommend any specific company for tranny rebuilds?
BTS in Arkansas or John Wood in Cali
