another flashing battery light - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-25-2009, 09:41 PM Thread Starter
trentdufour's Avatar
my Battery light started flashing Tuesday. by the time I got to work it was on steady. I got to the office popped the hood and checked the drivers side battery with a meter and got 12.2 volts with the engine running and 12.2 volts with engine off. so I removed the alternator and took it to the local alternator repair shop. I had it rebuilt. they said the voltage regulator and the stator was bad. I put it back on the truck tightened a loose battery cable on the drivers side battery and started it up. Checked the voltage again at the battery and 14.1 volts with the engine running. and my fluke meter with the amperage loop said my truck was pulling 69 amps off it with lights and ac on. So the alternator is working but the battery light is still flashing. I said maybe my batteries were low and just needed charged. I drove around for a day (mostly with the battery light off) Today I check the batteries with the truck off and they are both at 12.7v I start the truck and voltage goes to 14v battery light still flashing. I try to test the voltage at the field coil but couldn't get my probe in the hole because of the intake tube. I took the alternator off and took it back to the shop who tested it out said it tested fine but if I wanted I could leave it and he would take it apart at check the connections. I did, he did, and I picked it up this afternoon put it back on and tested it at 14v but still have a flashing battery light. I found the article on here about flashing battery light but my 02 does not have fuses named the same as the ones listed in that article.
Any Ideas would be very welcome.
Thanks in advance
2002 f250 supercab 4x4 7.3. so far only mod is a muffler delete and edge evolution
trentdufour is offline
post #2 of 4 Old 09-25-2009, 10:28 PM
InExactAxis's Avatar
I kind of had the same deal but instead of having my alternator rebuilt I bought a new one with a lifetime warranty. About a week after the new one was on my light started coming on again so I took the alternator off and they tested, they said it was fine and that it was most likely my batteries. I had both of my batteries tested and they turned out fine so I insisted that they replace the alternator that they said was good, because of the warranty they did and since then I haven't had any problems at all.
2008 Job3 F-350 4x4 CCLB 6.4L Harley Davidson Edition
1995 F-350 4x4 CCLB 7.3L Project Truck
SOLD!
2001 F-350 4x4 Lariat CCSB 7.3L
InExactAxis is offline
post #3 of 4 Old 09-27-2009, 06:07 AM
dave05250's Avatar
i had a similar problem with my 99 450 i finnaly found that the 2 wire connector on the alt had a bad connection internally there is a repair pigtail you can get to replace it
Took a dip in the D-Max world came back to the Stroke family,
2012 F-350 CC SB 4X4 Lariat
Leveled and stock...
2005 F-250 CC LB 4X4 LARIAT
CAI, 4"SS TURBO BACK EXH. STUDDED
8.5" SKYJACKER 4 LINK, REAR LADDER BARS
38X15.5X20 MICKEYS ATZ::::GONE
NEW:::2001 F-250 4X4 EXT CAB SB LARIAT
MUCH BETTER TRUCK
GONE
dave05250 is offline
post #4 of 4 Old 09-27-2009, 10:41 AM
I second checking the wires leading to the back of the alternator. that is what was wrong with mine
4 inch Banks Exaust
Stage II AFE Intake
Banks Chip
Halo HID Projector Healights
LED Taillights
LED 3rd Brake Light
Pro-Comp 3 Pod Guage Pillar
Billet Grill
2" Leveling Kit
Rear Air Bags
Future Projects:
CCV Mod, Zoodad mod, Injectors, And DP Tuner
Bambam03stroker is offline
