Trying to do the hutch mod and I am having a heck of a time getting the second fuel line disconnected from the tank. I got the first one but the second one is giving me fits. How far can I drop the tank before there are clearance issues with the lines? I have the disconnect tools but can't seem to get it to work. Any thoughts?
push in and turn at same time ,, there is enough fuel line,, as long as it is original .push connection together as u are tryin to use line tool at same time. it will come , and they are 2 different sizes also, so to different fuel line tool's!!.. good luck !!
Also if you can get to it, sometimes it helps to spray penetrating oil into the connector. dirt and road crud can get in there and not let the tool work just right and the penetrating oil will soften the dirt and grime and might help with removal.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
