my truck sucks - Ford Powerstroke Diesel Forum
Old 03-01-2007, 04:28 PM
Question my truck sucks
hey i checked the ebpv and whether it's closed or open it's still not running right, could the fuel pump be sucking to much water? it gets enought fuel to idle right and for slow atarts off the line but no boost when you put the pedal to the metal. after 2500 rpm's it'll shift but it should have some serious boost at around 200rpms but i don't get the bosst at all. any thoughts people.....thanx
Old 03-01-2007, 05:14 PM
The Fat Mod
Not sure, but I will bump this up for ya so maybe one of the techies will see it. Good luck with your problems.
Old 03-01-2007, 06:20 PM
Desert Shield/Storm Vet
Check all your boots for your intercooler pipes and makes sure you don't have a leak anywhere.
Old 03-01-2007, 07:17 PM
Nuckin' Futz
Yeah check your intercooler pipes as well as for exhaust leaks...also your wastegate might be stuck open and not letting any exhaust gases to your turbine wheel. Shoot it up with WD40 and operate the actuator by hand to get it broke loose.
Old 03-01-2007, 07:35 PM
Moderator
Send a message via Yahoo to 00powerstrokin
is it makeing a loud hissing noise?
Old 03-01-2007, 07:58 PM
International Threat
If you don't want it I'll take it
Old 03-01-2007, 08:23 PM
Nuckin' Futz
well hey is the loud hissing coming from the tail pipe if so then your EBPV is stuck shut...again just get after it with some WD40 and work the actuator rod by hand to free it up...once you have freed it up disconnect it...by unplugging the two wire connector that goes to the EBPV actuator solenoid on the back of the pedistal...this will prevent it from closing ever again and you will never have to worry about it.
Old 03-02-2007, 07:08 PM
my truck sucks
You're right. Once you get her running right, she'll suck the paint off those other trucks Just out of curiosity, when did you change your fuel filter last?
