anyone sell rebuilt rears? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-22-2009, 04:18 PM Thread Starter
I have been posting like crazy asking diff questions. I just installed a new to me rear. All bearing noise is gone. But, there is a clunk. I removed the cover and the ring gear is all shiny on one side. According to drivetrain.com thats not right. It feels that the play is between the ring gear and the pinion gear. I can spin the wheel with the tire when jacked up. I am holding the yoke. I can feel it. The limited slip seems good. No major, or any, growling or whining. But the clunk. Is there a east coast company that does exchanges? I have an extra core now. If someone has a rear with 4:10s and making no noise I could be interested.
l
melmount is offline
post #2 of 4 Old 09-22-2009, 04:35 PM
Originally Posted by melmount View Post
I have been posting like cray asking diff questions. I just installed a new to me rear. All bearing noise is gone. But, there is a clunk. I removed the cover and the ring gear is all shiny on one side. According to drivetrain.com thats not right. It feels that the play is between the ring gear and the pinion gear. I can spin the wheel with the tire when jacked up. I am holding the yoke. I can feel it. The limited slip seems good. No major or any growling or whining. But the clunk. Is there a east coast company that does exchanges? I have an extra core now. Ifsomeone has a rear with 4:10sand making no noise I could be interested.
l
That clunk you hear may or may not be normal. It depends and is hard to tell without looking for myself. I have built quite a few 9" and DANA 60 units. The unit should have some backlash between the ring and pinion. This is true for any type of rear. How much is what matterrs. The reason the ring gear looks polished on one side of the tooth and not on the other side is because one side is coast and the other drive. The drive side will polish over time because of the force on the drive side from the engine. When they are new the clearance is much more tight than when you rebuild them. All the parts in the rear end will get loose over time. But again it's more about how much. If you have u joints in the shaft that are wore it will make the clunk much worse. To test this put it in drive and set the ebrake. The put it in nutral and back to drive. The go from drive to reverse and see if the noise is different. If it's louder then start looking for ujoints with play.
2000_f350 is offline
post #3 of 4 Old 09-22-2009, 04:39 PM
just wait for it to blow. rearends are always to to smash lol does your truck have the ford 10.5
Don't hate me because I DRIVE A POWERSTROKE hate me because I'm banging your wife
97 powerstroke 240K miles
2 wheel drive to 4 wheel drive swap
gauges
3 DP
5 inch exhaust
H2E
intercooler
stage 3s
910 springs
stealth stage 1 hpop
air dog
regulated return fuel system
TW chip
john woods trans
4.11s rearend
2 kicker cvr 15s
1500 watt amp
kenwood deck
mean97 is offline
post #4 of 4 Old 09-22-2009, 04:51 PM Thread Starter
dana 80,
oh, 2000 f350, I can go from drive to nuetral back to nuetral and to drive. i am pretty sure it does not clunk. Drive to reverse it does, reverse to drive it will.
melmount is offline
