Trans temp sensor placement and boost placement
Anyone have a pic of the port the trans temp sensor should screm into?
Also where to tap for the boost gauge? NeillBarber |
Neil on my truck the trans sensor screws in just above the linkage drivers side,there's a plug remove the plug you're going to get alittle tranny fluid so put your finger over it.
your boost fitting goes in your air intake horn you can drill it and tap it or you can go to dfuser.com and buy the AIH delete plug with boost fitting hope this helps you out.
Im not sure if you have a 7.3 or a 6.0 so I will give you links to pics for both.
3-Gauge Install Pictures 3-Gauge Install Pictures |
Here is the AIH plug with boost fitting. This is the way I tied my boost gauge in. No drilling just remove the Air intake heater and replace with plug. You will need the code eleminator right below it also.DFUSER.com - Performance Diesel Products and Parts
