how to get bastard stickers off the truck?? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 09-22-2009, 06:59 AM Thread Starter
I have 2 stickers on the paint that I want off. They are on there GOOD and I cant seem to peel them off without excessive amounts of messing around. Is there any easier way? Rubbing alcohol?
Matt
85_305 is offline
post #2 of 16 Old 09-22-2009, 07:05 AM
Ryeman2138's Avatar
Use a heatgun or hairdryer to heat up the sticker. Then pull off the decal. Use an adheisive remover to get the remaining glue off. (goo gone, 3M adheisive remover) If have a local sign shop, pop in and ask if you can use some rapid remover (by far the best choice.
2007 F250 Lariat
Stock for now (Still Has Warranty)
Ryeman2138 is offline
post #3 of 16 Old 09-22-2009, 07:06 AM Thread Starter
ok thanks very much. I'm gonna try the hair blower trick, then use alcohol to remove glue, then wax the hell out of it when I'm done.
85_305 is offline
post #4 of 16 Old 09-22-2009, 07:08 AM
wriott
Guest
Posts: n/a
Quoted: Post(s)
yup use heat to remove them then a cleaner to get the glue off, you will be good to go
post #5 of 16 Old 09-22-2009, 07:11 AM Thread Starter
awesome thank you very much. they are driving me crazy
85_305 is offline
post #6 of 16 Old 09-22-2009, 07:18 AM
Barchetta's Avatar
Send a message via AIM to Barchetta
I've had great success with an angle grinder. Just gotta be careful not to use too much pressure.
I think you have some good ideas to get you started. One thing to add, take your time. The slower you take it, the better it will be.
Mark
2008 F-250 Lariat CC 4x4 AKA: Jolene
Dual Alternators (from the factory)
5% Tint All Around
High Idle Mod
Line-X
Roll-N-Lock
Clifford 50.5x
Barchetta is offline
post #7 of 16 Old 09-22-2009, 08:12 AM Thread Starter
noted. Thanks man. Probably gonna do this in the next few days. And I dont mean with an angle grinder
85_305 is offline
post #8 of 16 Old 09-22-2009, 08:16 AM
bfloyd4445's Avatar
Quoted: 3 Post(s)
hair dryer will do er that is if you have one of the old ones that gets hot before they put a temperature controller in them to keep people from burning themselves. I bought a milwauki one designed to remove paint and it works very well
Britt
2007 F250 CC SB 4X4, SB, PSD, Lariet, stock
1975 Ford 2000 ROP Diesel tractor < ran without oil for 2/10 mile 7/12/2009> Stills runs as good as ever
"If you don't read the newspaper you are uninformed,
If you do read the newspaper you are misinformed."
-Mark Twain
bfloyd4445 is offline
post #9 of 16 Old 09-22-2009, 08:17 AM
back in the saddle
shu873's Avatar
I use a hair dryer and goo gone. Works like a charm. You'll never even know the sticker was there in the first place.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #10 of 16 Old 09-22-2009, 08:18 AM
Quoted: 5 Post(s)
I prefer the sandblasting method myself..........
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
