Need Steering Stabilizer Suggestions - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-22-2009, 05:37 AM Thread Starter
OHBandit's Avatar
Running 35's on a 4" lift and the old stock steering stabilizer needs replaced. Should I go with a stock replacement stabilizer or with a dual set-up?
2003 F350 Lariat Crew Cab 8' Bed 4X4 7.3 PSD
4" Pro Comp Lift
MotoMetal 951's W/Toyo MT 35X12.50's
Power Hungry FU Chip
ITP 4" Ported Compressor Housing
4" Turbo Back Exhaust Straight Pipe
S&B Air Intake W/Zoodad mod
Pillar Gauges: Boost, Trans Temp, Exhaust Temp
6.0 Trans. Cooler
Recon smoked cab light lenses
LineX Bed Liner
OHBandit is offline
post #2 of 3 Old 09-22-2009, 08:04 AM
Powerstroke Junkie
NCHornet's Avatar
You can go with Bling bling, or you can go with Monroe, I used their reflex shocks and loed them. The Stabalizer was Monroe too, but not sure if it was Monroe, it's a lot more beefy than the puny stock one. Good Luck.
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #3 of 3 Old 09-22-2009, 05:36 PM
Get a dual kit.
Late 99 F250 ext. cab 4x4 Lariat 7.3
robthebuilder is offline
