What's normal EGT? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-01-2007, 03:36 AM Thread Starter
bamaboy473's Avatar
What's normal EGT?
An EGT gauge was installed using the hose-clamp method by drilling a hole into the exhaust about 4" from the turbo. Now I'd like to know whether or how much difference the temps are between that location and coming off the header location.
The X runs almost exactly 400 during around-town driving at 70 degrees. Accellerate hard from a light up to 70mph and the temp gets up to 700.
No chip involved. Are these temps about what's expected from a standard setup?
bamaboy473
2000 F350 7.3 PSD
6" suspension lift
4" cat-back exhaust
air filter mod
20" wheels
bamaboy473 is offline
post #2 of 7 Old 03-01-2007, 03:58 AM
ADMIN AND TECH
SCUFFY828's Avatar
sounds normal to me
ITS STOCK
SCUFFY828 is offline
post #3 of 7 Old 03-01-2007, 01:02 PM
Lord Tauk's Avatar
Pre Turbo: My EGT 500-600 at 40-60MPH, standing on it for a few seconds from a roll reaches around 800. This is 30-50 degrees outside.
Lord Tauk is offline
post #4 of 7 Old 03-01-2007, 01:32 PM
SMOKE ROLLER
Rescuediver's Avatar
My pyro is in the driver's side header. I range from 550-750 depending on the amount of right foot during acceleration. If I role smoke (aka hammer down) It keeps climbing 1000, 1100, 1200...
TERRY
BIG RED - SOLD
4" SILVERLINE TB
SCT w/Edge INSIGHT
6" Superlift w/ 37" TOYO'S on 20's
Accufab Elbow
Lots of Recon Lights
HID Headlights & Foglights
Train Horns
SNOW H2O/Meth
Rescuediver is offline
post #5 of 7 Old 03-01-2007, 01:57 PM Thread Starter
bamaboy473's Avatar
Would it be a decent assumption that installing the probe into the header might add 150-300 degrees to the pyro readings compared to adding it up near the turbo? I can't get the pyro over 800 so far.
bamaboy473
2000 F350 7.3 PSD
6" suspension lift
4" cat-back exhaust
air filter mod
20" wheels
post #6 of 7 Old 03-01-2007, 04:39 PM
SMOKE ROLLER
Yes your probably right, the key is to provent you turbo from burning up. Most manufacturers tell you to drill and tap it into the elbow of the manifold. I guess if you run it too high there maybe the theory is you still have some room before you burn the turbo up.
TERRY
BIG RED - SOLD
4" SILVERLINE TB
SCT w/Edge INSIGHT
Accufab Elbow
Train Horns
SNOW H2O/Meth
post #7 of 7 Old 03-03-2007, 03:08 PM
99Smokin73Stroker's Avatar
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Give yourself more room than that. The post turbo reading can vary as much as more than 500 degrees! At normal crusing, they're pretty close on my gauges. I have pre and post. But at full on balls to the wall, I (used to) get over 1400 while the post gauge still had yet to get over 1000.
2005 F350 XLT FX4. 2.5" leveling kit, 03 turbo, 4" MBRP Turbo-back, 58v FICM, SCT X4, Irate Diesel coolant filter
99Smokin73Stroker is offline
