Another Fuel Leak ? Small hard to find Leak - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-18-2009, 04:27 PM Thread Starter
chrispaine's Avatar
Well I got everything out of the way and cleaned the heck out of the valley, today after driving about 25miles of highway I open the hood and check for leaks. There is a small amount of what looked to be fuel, it was too hot so I waited for it too cool of so I could stick my finger in it to see what it was. I waited a while, ate dinner, when I came back it was gone. So it evaporated somewhat quick, think it was fuel? It was in the the second from the front 'low spot' in the valley, right under the spider. I started it and watched for leaks but it must be a slowww leak because I can't see it! Now I did do a search and found about a hundred things to check, just wanted to see if anyone has seen something similar, or has some idea. Thanks!
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #2 of 4 Old 09-18-2009, 06:41 PM
Cumminskiller2007's Avatar
look behind the fuel bowl passenger side if there is a rubber hose connected to a steel fuel line to the bowl check that cuz I just had to replace mine do to leak, and a buddy of mine had same problem, check out let me know
2001 F350 S/C 4x4 DRW 6spd
475K
DpTuner-high idle, 80E, 100Perf, 120Race, 4inch TB exhaust with 5in. Single black Stack, Custom 4in. intake with AEM dry filter, ISSPRO boost,pyro and water temp, zoodad mod, Beans 1.0 A/R non wastegate turbine housing
Cumminskiller2007 is offline
post #3 of 4 Old 09-20-2009, 07:05 PM Thread Starter
chrispaine's Avatar
Thanks for the tip man, I'll check it out!
The weird thing is sometimes there is a small amount of a fuel puddle and sometimes there's not. Can't pinpoint it, maybe it's only after highway driving.
On the way--
post #4 of 4 Old 09-20-2009, 07:19 PM
If it is that then your fuel bowl drain is ope or something is jammed in there holding it open, cuz that hose is the drain line
475K
