Sway Bar bushings question
This kit dosent list the diesel as an Option, any reason why it wouldn't work? I can't see it being different. Will a kit like this make new sway bar links not needed, it will replace the bushings in the links correct?
1999-2002 Ford F-250 Super Duty Energy Suspension Sway Bar Bushing Kit Red|Ford F-250 Super Duty|Ford|Energy Suspension Bushing |
The bushings are what wears out so replacing just the bushings is all that is required. No need to buy the whole link. That part # doesn't seem right though. Check this link for instructions and part #. It is for a 2004, but they should be the same on your 2000. I used the same part # on my 2001. Hope this helps.
Replacing the bushing is a real pain!! I just replaced the entire end link, much faster and no headaches!!
NCH |
Thanks for all the info! |
The worst part is getting the old ones out. If you have access to a press, the job is real easy. The rest is bolt up.
i did mine when i first got my truck.. it took me about 45 mins totall
Did you use a press or do it by hand?
I bought those exact ones when I first got my truck. They were all very cheap and all the wrong size. I tried to return and they wouldnt write or call back. Pissed me off. I dont think you can really just change the bushing, get the whole link from napa for about $50
