Warn Hubs - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-27-2007, 05:22 PM Thread Starter
LPstroker's Avatar
Warn Hubs
I have a 03 F250 4X4 Manual Transfer Case with the 7.3L Can I switch out the Stock ford Manual Hubs for Warn Hubs? Also I think that because I have a Manual Transfer case and not the electric switch I think that my hubs are not vacume operated. Am I correct? Can someone comfirm for me, I think that when I have my truck in 2WD that there is no power going to the front diff. Am I correct?
"The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government."
Thomas Jefferson
03 F250 FX4
7.3L 4X4
4-inch Turbo Back Straight pipe.
DIY Tymar intake.
285/75/16 Cooper ST Maxx
181K
LPstroker is offline
post #2 of 12 Old 02-27-2007, 05:26 PM
HardLuck Case of the Year
Ditty's Avatar
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Yes, yes you can. It is a HIGHLY recommended upgrade. I've never heard of anyone blowing out a Warn Hub, but I've heard of 100's of folks blowing their stock Ford POS hubs.
DITTY
Brisco:-White 2000 F-350 PSD CrewCab/SRW/LongBed/4x4/6spd Manual/HUGE Powerstroke.Org Vinals!
Favorite Mods: Baby-seat mod/Girlfriend delete/6pos on Xtreme!
Repairs since bought: both batteries/alternator/3 transmissions/4 clutches/entire front axle/new steering stabilizer/power steering pump
Still broken: cracked windshield/all glowplugs/glowplug relay/4WD still out/trailer harness no power
Current Best: 16.149@84.13MPH (Est.7800lbs)
Ditty is offline
post #3 of 12 Old 02-27-2007, 05:34 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
Mine engage when they get power from the axles, not vac operated.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #4 of 12 Old 02-27-2007, 05:34 PM Thread Starter
LPstroker's Avatar
What about the rest of my questions? Are my hubs free spinning when I have them on "Free"?
Thomas Jefferson
03 F250 FX4
7.3L 4X4
DIY Tymar intake.
181K
post #5 of 12 Old 02-27-2007, 05:37 PM
Yes, when in free they have no transfer to the drive line.
Derrick
post #6 of 12 Old 02-27-2007, 05:43 PM
Superwrtech
To find out if your hus are working jack up the front end and put the hubs in lock position. Turn the wheels and the axel should turn. If it does not the hub is bad. On your truck I dont think the hubs will automatically engage. In the winter I lock mine in for the season and engage the four wheek drive when I need it. Hope this helps
Bruce Johnson is offline
post #7 of 12 Old 02-27-2007, 05:44 PM Thread Starter
LPstroker's Avatar
So the free spin hub conversion kit that dynatrac.com sells would probably be for someone that has the electronic transfercase.
Thomas Jefferson
03 F250 FX4
7.3L 4X4
DIY Tymar intake.
181K
post #8 of 12 Old 02-27-2007, 05:47 PM
Superwrech
Don't know about them but I know that warn makes the best hub.They can repace manual or automatic locking hubs
post #9 of 12 Old 02-27-2007, 05:56 PM Thread Starter
LPstroker's Avatar
Thanks for the help
Thomas Jefferson
03 F250 FX4
7.3L 4X4
DIY Tymar intake.
181K
post #10 of 12 Old 02-28-2007, 11:13 PM
99 7.3's Avatar
lpstroker, i believe that all the psd have vacuum operated hubs. weather manual or auto. transfer case. all u have to do is look at the top of ur spindle and see if u have a line running into the top of it. that is the vac. line for the hubs. warns will hook right up for u.
built trans, hybrids, studs, and other internal mods.
99 7.3 is offline
