CEL and MAP Fooler question - Ford Powerstroke Diesel Forum
Old 02-26-2007, 06:49 PM
With the mods listed in my sig, as expected the CEL comes on when I go WOT. I understand that the MAP fooler will prevent the light from comming on. My question is does the engine begin de-fueling when the light comes on? Or does it actually perform the same with or without the fooler, with the only advantage of having a fooler being no light??
Old 02-26-2007, 07:27 PM
No. Your map fooler doesn't allow the map to see the boost thereby not sending signal to ICM to defuel
Old 02-26-2007, 07:37 PM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
When your getting on it and you hit about 22-24 psi, the map sensor sends a signal to the computer, saying "Dude...too much boost!!!" The computer sets the CEL off and goes into defuel mode, forcing the boost to lower.
With a mapfooler, you can exceed the 22-24 psi b/c the fooler only lets the map sensor see 22psi max and therefore no "Dude...too much boost!!!" code to the computer.
I have a MapFooler from ITP...took about 20 mins to install and works flawlessly. (Just do NOT mess w/ it when you get it!!!) I'm hitting right at 29 psi at full throttle with NO CEL or defueling! I'm soo happy!
Personnally, I feel that some type of mapfooler device is mandatory for a modified PSD!
(Ohh yeah... WHOOP AGGIES!!!!)
Old 02-26-2007, 08:26 PM
I have the dual release valve but, I'm going to get rid of it and get the ITP Boost annihalater, better fooler I THINK. Oh and I think it's SES light LOL
Old 02-26-2007, 08:33 PM
Yeah...I looked at the relief valve and the foolers. I don't like that the relief valves allow a 'leak' in the boost pressure. The ITP fooler does not allow any 'leak' and just limits the amount of boost that the mapsensor sees.
Old 02-28-2007, 07:54 PM
So the one from ITP is an electrical device?? I thought it was a mechanical device which means it has to relieve boost somehow. Right or wrong?? Of course it wouldnt be the first time I've been wrong.
Old 02-28-2007, 08:03 PM
Desert Shield/Storm Vet
I might be wrong but Im pretty sure its mechanical it just doesnt bleed any boost off!
Old 02-28-2007, 09:08 PM
Then how does it keep the MAP sensor from seeing excessive boost??
Old 02-28-2007, 09:16 PM
Here is an explanation of it Overboost Annihilator
Old 02-28-2007, 09:23 PM
It says its a regulator which means it bleeds off boost. Am I right or wrong??
