What rpm's do you guys shift at for economy? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 08-29-2009, 05:52 AM Thread Starter
I know... 7,000 lb truck.. economy.. funny.
But about which rpm do you guys shift at? In my honda I shifted about 3k rpms for max economy, though 3k rpms in this truck is almost red line. I've been shifting the truck about 1500 rpms maybe? I drive it so that you can barely tell its being driven and I dont let the turbo spool at all. This seems like the logical shift pattern for economy but lets hear it from the Pro's..
Matt
85_305 is offline
post #2 of 21 Old 08-29-2009, 05:58 AM
2000 7.3 6speed's Avatar
just under 2000
2000 7.3 6speed is offline
post #3 of 21 Old 08-29-2009, 06:02 AM Thread Starter
And here is another question.
I know all cars are different.. but do these like very very light throttle to get up to speed, or just barely touching the diesel pedal?
What kind of mileage you get shifting at around 2g?
85_305 is offline
post #4 of 21 Old 08-29-2009, 06:42 AM
kimber_da's Avatar
Send a message via Yahoo to kimber_da
I've got a 6.0 with the 6 speed. From 1st to 2nd, I'l shift about 1500 and work my way to around 2000 when I shift Into 5th. See what I'm saying? My economy will be a little different from yours, but when I do this and drive around 55mph, or draft a bigger vehicle at higways speeds, I'll see anywhere from 20 to 22 Mpg. I drive like this most of the time, but every once in a while I drive it like I stole it. These trucks love and need to be run hard every once in a while.
The above opinions are my own and should not be substituted for common sense.
03 F-350 6.0 6speed
kimber_da is offline
post #5 of 21 Old 08-29-2009, 07:02 AM
i wuz told by a teacher in a diesel school itz good 2 shift around 2K RPM !!!
-Mike-
2006 F-350 Lariat, Supercab, 6.0L, 3.73's...Rhinolined Bed...6 Spd Handshaker...Mag-Hytec Diff. Covers...Smoked Recon Lights...Amsoil oils front 2 back...Optima Yellow Tops...MBRP 5" ST8 Pipe, Turbo Back...Dieselsite Coolant Filter...Amsoil/Injen CAI...SCT SF3 Canned Tunes 4 Now...CFM Intake Manifold and Boost Tube...Blue Spring Upgrade...Edge Insite CTS !!!
pete37922 is offline
post #6 of 21 Old 08-29-2009, 07:27 AM Thread Starter
Ya as a matter of fact, I just went and ran some imaginary errands and I found myself doing the same thing.. slowly increasing the RPM in which I would shift at. Is that 20-22mpg city, highway or mixed?
But I know what you mean about the truck begging to be driven hard; it seems to love it so far. And it's hard to resist. Ya always gotta play with your new toys!!
good info, thank you
85_305 is offline
post #7 of 21 Old 08-29-2009, 07:57 AM
Tree Killer's Avatar
with a 6.0 and vgturbo, i was told by a ford diesel tech that they should be worked and run at high rpm's to keep the veins from getting crap built up on them and then sticking. Not run high rpms all the time but when u can stretch her legs when u can. u don't want it to load up ( like a 2 stroke) lol it may effect your fuel economy a bit. look at the way a auto shifts when u get on it it'll hit around 3000rpms before it shifts. with my 6speed i get around 19.5 mpgs
2004
F-250 XLT Lariat 4X4 6.0, 6 SPEED
Lunch Bucket Included
KEYSTONE COAL ROLLERS
Support the Loggers;Wipe ur A$$ and Build Something! DAMNIT !!
GOING GREEN,IS A LOAD OF BROWN;Anthony Cumia, 2009
WARNINGMOST POSTS ARE DONE UNDER THE INFLUENCE OF JIM BEAM
Tree Killer is offline
post #8 of 21 Old 08-29-2009, 08:00 AM Thread Starter
Ya you def. need to strut these things out once in a while to prevent loading up. Same with gassers too. But I think moreso on the diesels.
Is that 19.5 mpg city, highway or mixed driving?
85_305 is offline
post #9 of 21 Old 08-29-2009, 08:12 AM
The reason why you need to run higher rpms on the 6.0's is because the turbo has the moving exhaust vanes inside the exhaust side of the turbo, if you dont get on the fuel sometimes they will not get exercised like they need to be, thus they will start to stick in place.
2003 Ford F250 Crew-Cab 4X4 7.3L 350HP
2000 Ford Excursion 4X4 7.3L
1993 Mazda Rx7 Coup 1.3L 574HP
2003_F250_FX4 is offline
post #10 of 21 Old 08-29-2009, 08:13 AM
19.5 highway. @ around 72-75 mph. in town or rural roads (home) it'll normally get a lil higher, 55-60 mph seems to be the sweet spot for mine
2004
