Shocks
Will front and rear shocks off an 05-06 fit a ninty nine?
Hmm good question. My guess is probobly not because the 05-06 have coil springs versus leaf spings on a 99. Im sure someone will be able to tell you for sure
The rear should fit with no problem. The fronts maybe a different style as the suspension is different the new trucks have the coil springs as mentioned. You have leaf springs. But as long as the mounting is the same then they should work. Why do you want to go with factory oem shocks off a newer truck. If you are needing to replace your shocks I would suggest something with a better ride from an aftermarket company. If you are looking at leveling out the front of your truck the shocks will not do it. You will need to get a leveling kit.
I have already leveled my truck it it just needs some shocks and i can get a set of ranchos of a new body style cheap for all four.
as long as the mounting is the same they should work.
