6 speed manual fluid - Ford Powerstroke Diesel Forum
Old 08-12-2009, 09:25 PM
Howdy all.
Want to change the fluid in my new to me truck. It is a 03 F350 7.3 6spd manual 4x4 dually.
What fluid do you recomend for it and should I use any additives. Also whats the capacity?
Any recomendation on the transfer case would be great also.
Thanks
Old 08-14-2009, 06:05 PM
No body knows ?????????
Old 08-14-2009, 06:08 PM
think it takes regular atf, fluid type and capacities should be in your owners manual
Old 08-14-2009, 06:16 PM
It takes regular ATF I think Mercon V. I put Royal Purple ATF in my former 00 and it seemed to shift smoother, Gear changing seemed to slide into place better.
Old 08-14-2009, 06:46 PM
Cool. Thanks for the help.
I would look in the owners manual if I had one but since truck was a repo when I bought it no maual to be found.
Thanks again.
Old 08-14-2009, 09:03 PM
I have one regular ATF for the ZF6
Old 08-16-2009, 05:32 AM
Thanks again.
You should use Mercon V for both the tranny and transfer case. Not sure of the capacity of the manual tranny because I have a atuo, but my transfer case takes about 2 quarts.
I use AMSOIL products for all my lube needs. I think they really make a difference, but I am a little biased too. I am a dealer. Because of their extended drain capabilities you don't have to worry about changing fluids so often either. If you want a little more info, PM me I would be glad to shoot you some product info.
Old 08-16-2009, 01:18 PM
If I remember correctly there is a ton more fluid in the ZF6 vs the ZF5. Something like 12-16 quarts, it cost me a good penny when I put the royal purple in my old truck.
Old 08-16-2009, 01:20 PM
6qts of ATF.
