Shims under my factory Leaf springs?
I just put a 4" Lift on my 2000 F250 4x4. On the drivers side only, under the leaf packs I found 2 shims (4 total) under the leaf springs(2 front and 2 rear). The were not tappered, just flat. Each was approx 1/8 thick. Its like they are trying to make the driver side of the truck sit taller? What gives? I kept them but didnt put them back when I put the lift kit on? Should I?
Oh and does anyone know the torque specs for the U-bolts and leaf spring eye bolts? Thanks |
thats weird. i coldn't tell ya what the torque specs are. i just made mine good and tight
so I take it yours didnt have these shims or spacers?
nope mine didn't have any
are the shims blue. i think they are supposed to be there. from what i ws told its a tsb its upposed to stop a squeak or something like that . mine has them in there also.
the torque specs on the front u-bolts are 185 if i remember right and i think the eye bolts are ridiculously tight like 290!
when I get home I will check the manual and post the proper torq specs for you.
The shims are not blue. They were metal. The same size as the spring pad on the axle and 1/8 thick.
I have a 96. I have the same thing only on the pass. side. Ididn't put them back in and 2 weeks later my truck sits lower on the pass. Iguess i'm puttting them back in. Good luck!
