code/sensor questions
i just pulled some codes from my truck this afternoon i got
p1280 icp circuit out of rangle,low p0472 exhaust pressure sensor low p1690 wategate solenoid control circuit p0236 turbocharger boost sensor A p1211 icp pressure above/below desired p0476 exhaust pressure control valve performance my gf's dad said i should start by changing the exhaust pressure sensor then the wastegate where is the tubo boost sensor? and should i change the icp too? ![]()
Is there anything wrong? Looks to me like a harness got unplugges somewhere or something for all of those problems at once. The icp sensor code can sometimes just be caused by a chip and im guesing some of those other ones could too? Heres a bump for u anyway.
well kind of its been running kind of sluggish lately i just changed the driver side valve cover gasket could only do one...started raining the harnesses all looked good no cracks im gonna get a new wategate and see if the solenoid is good yet idk its been driving me nuts lol
To many codes, they could be months old or older. Clear all of them and see what returns. The EBS code is probably due to carbon build up on the base of the sensor and in the tube, clean it with brake cleaner and you may be okay. I was able to clean mine twice before I needed a new sensor.
NCH |
Im with Kevin here. Clean the Exhaust backpressure sensor.
The rest of the codes are because of your chip commanding more ICP and the truck making more boost than ford spec. Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page The link above tells you how to do it |
i dont have the tube lmao its gone i was gonna buy a new tube for it should probably do that huh?
ok lol you know where i can get one ??? d-fuser has one for 70 can i get it cheaper from the dealer? or anywhere else thanks
Check the dealer or an IH big truck dealer. IH will probably be the cheapest
i have a new set of exhaust manifolds coming to so ill wait til i get them to put the tube on....
anyone know where i can get some bolts for the manifolds? advance auto cant get em i was gonna try the dealer but if i can get them cheaper elsewhere ill do it |
