Need help on 99 f-250 - Ford Powerstroke Diesel Forum
Old 08-08-2009, 07:32 PM
What could the problem be on a 99 f-250 7.3 when the abs light comes on and the speedometer stops working and the overdrive off light is flashing at me. Everything works fine the overdrive still works the truck still drives good and shifts good.
Old 08-09-2009, 04:44 AM
Powerstroke Junkie
Does your speedo function correctly? If the OD light is flashing you have driveline codes, I would get them read first. Could be a simple VSS gone bad on the rear pumpkin.
NCH
Old 08-09-2009, 06:09 AM
No my speedo does not work at all when if first quit it would flicker a little then go down to 0. Sorry but what is a VSS?
Old 08-09-2009, 06:13 AM
rear speed sensor
Old 08-09-2009, 11:03 AM
dmd dmd is offline
Vehicle Speed Sensor is in the rear end. It is a sensor that tells the computer how fast
the truck is moving. Probably just needs to be pulled out and cleaned.
