PLEASE HELP, I BENT MY FRAME. - Ford Powerstroke Diesel Forum
post #1 of 16 Old 08-06-2009, 03:09 PM Thread Starter
bignasty250's Avatar
Send a message via AIM to bignasty250
k well i guess i messed up pretty bad, i was turning onto the road while i was texting and i guess it got the best of my because i never stopped turning and ended up going into the ditch (which was just dug to about 4ft) i hit it doing about 15 and i took it to go get checked out and the passenger frame rail is buckled in the front and is bent about an inch down. is there anyway of pulling the frame back straight???? and also i bent the front hangers and the axle is twisted inside the frame a slight bit. any help at all would be apreciated i dont want to lose my baby cause of this
here the truck i will get pics of how it looks now a little later on
bignasty250 is offline
post #2 of 16 Old 08-06-2009, 03:12 PM
OregonStroker's Avatar
wow that f-ing sucks man. Im sure you could fix it. it will be spendy tho. Prob need to take it to a couple body shops.
Built engine, rods, pushrods, cam, springs. Meth, turbo, injectors, fuel system, oil system. 3 disk billet, billet shafts built trans, 6.0 IC, exhaust, intake. Latter bars, gears, system, tint, HIDs. You know the typical stuff to make a 7.3 get out of its own way...
dont brake.
OregonStroker is offline
post #3 of 16 Old 08-06-2009, 03:27 PM Thread Starter
how much is spendy lol
post #4 of 16 Old 08-06-2009, 03:27 PM
ummmm, dude thats a pretty serious fix. do you have some metal fab friends?
dont brake.
post #5 of 16 Old 08-06-2009, 03:29 PM
the spring hanger and springs arent too big of a deal, might just be the bolts that hold the hanger on. from the sounds of it you bent the spring too. thats gona be kinda spendy. you'll have to contact the manufacturer and see if they will sent you a new one. as for the frame- you may have to chop out and replace the bent portion. these frames are fairly serious. do you have any pictures yet?
dont brake.
post #6 of 16 Old 08-06-2009, 03:30 PM
if i read your posting right, it sounds like the frame where the hanger bolts to is bent?
dont brake.
post #7 of 16 Old 08-06-2009, 03:49 PM
00strker's Avatar
wreck it not a joke it will never be right
2000 7.3 Few mods...SOLD
2003 Common Rail tow rig / DD
2006 Harley edition F-250.. 10in Fab, 24in Rockstars, 38x14 Kuhmos, 4in MBRP, Gearhead tunes...NO STUDS
00strker is offline
post #8 of 16 Old 08-06-2009, 03:54 PM
jdstroker6.0's Avatar
Yeah frame problems are serious and hard to fix, even if someone can fix it odds are you will never be able to keep it aligned. you probably dont wanna hear this but i would scrap it or pawn it off on a dealer.
2008 F-250 4x4 Lariat
Nitto Trail Grappler 35x12.50x20
Stock (for now)
jdstroker6.0 is offline
post #9 of 16 Old 08-06-2009, 03:55 PM
good time to UPGRADE (Cash for Clunckers) LOL
Stock (for now)
post #10 of 16 Old 08-06-2009, 04:07 PM
duct tape & zip ties
bigcountrysg's Avatar
First you have to find a shop that is willing to straighten it that much.
Back when I was certified to straighten frames. If it was more then 1/2 inch out it was not getting straightened. When pulling on a frame that much for that far of a distance. The metal gets hot and weakens. Making it that much easier to bend it again.
I would look for either another frame rail or new truck that you can put your lift on.
Oh btw there is a reason why you should not text and drive at the same time.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
