Brake controller questions???
Ok... I bought a Tekonsha Envoy controller for cheap and I already have the factory ford tow plug and I see where it plugs in under the dash....My question is which wires go where?
The tow plug has a label that says BROWN- Illumination (I am guessing this is not used) DARK BLUE- Trailer electric brake feed RED- Trailer electric brake control feed WHITE-Ground LT GREEN- Stop lamp feed to brake controller The blue and red are confusing the hell outa me! I understand the green and white ones but then it all falls apart.
dark blue goes to the trailer plug, red is the input from your brake pedal
I thought the green was from the brake light switch???
??? Help.....
are you talking the wire colors on the ford pigtail or on the controller pigtails when you say red and blue?
The ford wire colors are:
Red- Battery feed to brake controller Blue- Brake output to trailer Lt Green- Stop lamp feed to brake controller White- Ground Brown- Illumintion The brown one is not used on most controllers. |
I just found the same info on another site. I was getting confused when the ford plug says
DARK BLUE- Trailer electric brake feed RED- Trailer electric brake control feed But I got it now. Thank you! |
Don't feel bad I had to look at it a couple of times too.
Glad you got it worked out......this is the reason I ordered the Tekonsha harness when I ordered my Prodigy.
Don't forget to put in the relays under the hood. Some of them were left out for the user to install , check your manual on this. You could trouble shot that one all day long. Good choice on the control unit.
