white smoke on startup
I have been searching and still can't figure it out. I have changed out the glow plug relay with the stancor and just tested all my glowplugs. two I found were bad and changed them out. Still to find it smoking on startup when cold. Any Ideas????
probibly a bad injector
ok, I went out and checked the new relay and am not getting any voltage on the yellow, and brown side with key on. I will double check it in the morn with it sitting and cooling over night. I have been looking around on here and see that I can jumper it to check relay but with it being brand new stancor and still not getting voltage on that post I guess I am looking at a pcm prob. Any ideas of where to go from there if it is?
Went ahead and changed the other 6 glow plugs today, so all 8 are brand new and working. Also the gpr is brand new and works. Still having the same white smoke issue when the truck has sat for a few hours. Anyone have any ideas, it goes away after you get going down the road, just makes my truck look like a piece of junk on startup.
i am having the same problem please help
Im also having the same problem.
how many miles you guys have on your trucks?
I've always had white smoke when it is cold outside, until it gets into high idle.
