how much is too much? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-16-2007, 03:32 PM Thread Starter
I bought a 99.5 F 250 with the 7.3 powerstroke and an automatic. I am going to be pulling around 24000 lbs with it. Will it do it stock or do I need a chip? The pickup also has 135K on it.
rockyridge is offline
post #2 of 6 Old 02-16-2007, 04:45 PM
Stroked95's Avatar
Don't know if a chip would be the ideal first upgrade for towing 24k. I would look at things like bigger tranny cooler, 4 inch exhaust, big intake, some gauges, after those upgrades check out totaldieselperformance.com for a wildman 4 pos chip. If you plan on towing 24k regularly your trans proly won't last too long without a build up. Some other upgrades good for towing are a spearco 6L intercooler, and the turbonetics replacement turbo. You probably already have a way to stop all that wieght too right? Big brakes.
That would be the things that I would look at if I were in your position. Good luck
1995 Reg Cab F350
totaldieselperformance.comWildman Tuning
terminatorengineering.com Terminator Nation
wideopenperformance
Stroked95 is offline
post #3 of 6 Old 02-16-2007, 04:49 PM
sldghamr's Avatar
and if all that upgrading doesn't work, you can always get out and push
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #4 of 6 Old 02-16-2007, 04:52 PM
Big Tone's Avatar
Quoted: 2 Post(s)
Look at some firestone riderites, and an exhaust break also.
Big Tone is offline
post #5 of 6 Old 02-16-2007, 05:03 PM Thread Starter
would the tuner be an advantage or would I tear things up?
post #6 of 6 Old 02-16-2007, 05:29 PM
slammedSI's Avatar
It would sent the EGTS so hight it would melt the motor down.
-Bobby Crews- AKA Dr. Cookie Cutter!
2012 Ford F150 Ecoboost
-STOCK-
A 7.3 with an edge should never get into a race. Unless it's with a kid on a bicycle.. and the bike has a flat.
slammedSI is offline
