Leveling kit/Lift? Biggest tires without rub? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-02-2009, 06:09 AM Thread Starter
Hey everyone,
This is such a great site, the info is priceless. Anyway on to the questions.
When I got my '00 F250 7.3 4x4, the top leaf on the front drivers side was busted. I had a Rough Country leveling kit installed which raised the front 4" according to the installer. The rear was then 2" shorter than the front so I had a taller block put in to level the truck.
First question: Does this mean I have a 2" lift or 4" lift or other?
Second question: What is the biggest A/T tire I can use without rubbing?
The truck currently has 265/75 R16's
I'm new to truck modding (yes, I've got the bug). Your help would be appreciated.
Thanks,
BOMO
BOMO is offline
post #2 of 4 Old 08-02-2009, 06:16 AM
Sleeperstroke's Avatar
4" lift. The concern if your still on stock rims is rubbing your springs at full turn. 285s will do, and you MAY get away with a size bigger than that, even, but you should trial fit a tire and check it before purchasing to be sure. I do NOT recommend BFG ATs. They absolutely suck aBLEEPss in anything having to do with mud. I rue the day I decided to purchase them for Blizzard.
"Blizzard" The big white bio-burning 03 7.3. 6637, straight piped stock exhaust, and a "New" secret blend of Haul asBLEEPsing mods and upgrades. Suffice to say, its not the fastest, but it quite possibly is one of the quickest.
Sleeperstroke is offline
post #3 of 4 Old 08-02-2009, 07:50 AM
Powerstroke Junkie
NCHornet's Avatar
Superduty's are all lower in the front, so what you have is ezactly what you said, 2" in the rear, and 4" in the front, it isn't a complete 2" or 4", it is what it is, but it does look good. I hope that "leveling kit" came with a adjustable, or new drop bracket for the tracbar, hopefully both. As for tires, trying one on is good advice and one that I would follow. Don't know what to say about the BFG AT's I have run a few sets of them on previous trucks and they were great tires. Maybe they have changed something???
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #4 of 4 Old 08-03-2009, 01:44 AM
i put a 2.75" leveling kit on my 350, and i'm using 295/75/16 tires no problem my nitto terra grapplers are awsome.....
matter is offline
