Got some b day gifts coming, need help with tranny ?'s
So my girl wants to spend some money for my b day. I want to do some work to the tranny. I was thinking BTS valve body. What about Tricumulator Springs Kit? What else should i do while i am in there? Trying to make it last as much as possible. It was re built before i got the truck 10k ago and had the DP on it for 6-7k. Doesnt ever go above 140* unless towing my boat, and i don't beat it up to bad. Any suggestions?
You could put on an aftermarket pan that would cool it more.
BTS valve body is an excellent choice. Sonnax or Transgo shift kits are unnecessary then. I ran the Sonnax, and then the Transgo kits for quite awhile each and theyre both very very good. If you havnt upgraded your tranny cooler, you could do that too. I would go for the cooler upgrade before a larger pan, personally.
larger pan isnt going to do anything as far as cooling. install a 6.0 cooler and be done with that. my tranny never ran over 140* either, installed a 6.0 cooler and my typical running temps on a nice afternoon are 100-110* towing i see 140-150*
My tranny temps are 10-15* lower now that I have a bigger pan.
thanks for the correction! :thumbsup:
so do you recomend one? is 10-15* worth the money in your opinion?
Id say yes and no. I just got a deal on one that I couldn't pass up and I had to pull the pan to change the filter anyway. I think its the extra fluid and fins that help cool it. If you have the money I would buy one but I don't really think its necessary.
