Dome light has a mind of its own!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-29-2009, 07:23 AM Thread Starter
boatnut1978's Avatar
I have had this problem for a while. My dome light seems to stay on after I shut my doors, it seems to be mostley effected by the front passenger door.
You shut the door and the light stays on, drive until it shifts into second and it goes off. Then brake and slow down and it comes back on.
This is getting real annoying, especially when its dark out. And it does not do it all the time???? It has a mind of its own.
Help me please, can I disconnect the switch??? Where is it???
1999 F-350 CrewCab SB 7.3 International
5" Exhaust, Ford Fleet intake (huge)!!!
Map fooler, blow off valve cheeter, Dfuser tuner (looking for a better one..lol)
6" lift, 35" TOYO MT'S on 18" Venti's
Knocking in the front and Smoking out the back!!!
boatnut1978 is offline
post #2 of 5 Old 07-29-2009, 08:30 PM
jcs
jcs's Avatar
Spray some wd-40 in the door latches and open and close them a few times
early 99 7.3 supercab xlt s/b auto 4x4
08 Tailgate
Isspro gauges (boost,pyro,trans temp)
Ford AIS
jcs is offline
post #3 of 5 Old 07-31-2009, 07:50 PM
I second this. I had to do it to mine last year and has worked with no problems since.
1donos is offline
post #4 of 5 Old 07-31-2009, 07:55 PM
7004's Avatar
Wd40 works try it
Early '99 F-350 Ext. Cab LB
TS 6pos. Chip
Tranne is all better
K&N Intake
Zoodad mod
4" Downpipe
MBRP 5" Exhaust w/6" SS Tip
Boost Fooler
Quadzilla Recon
(Sold)'96 F-250 Ext. Cab LB
CENTER][URL
7004 is offline
post #5 of 5 Old 08-01-2009, 07:26 AM
Yes, I agree, but I used white lithium grease in a spray can- will last longer than WD40
robthebuilder is offline
