Break down VIN# - Ford Powerstroke Diesel Forum
Old 07-29-2009, 06:47 AM
Break down VIN#
Does anybody know how to break down vin #s? What kind of info is abtainable by breaking down the VIN? Is there a site i can go to that exsplains this?
1FTSW3!FXYEC81024.
Thanks
Dale.
Old 07-29-2009, 06:48 AM
Almostdunfukinwidit
Dale I'm assuming the exclamation point is a 1 Correct?
Old 07-29-2009, 06:49 AM
https://www.fleet.ford.com/maintenan...vinResults.asp
Old 07-29-2009, 06:50 AM
Almostdunfukinwidit
VIN: 1FTSW31FXYEC81024
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 1FT
Assembly Country: USA
Make: Ford
Body Style: Pickup
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: S
Brake System: HYDRAULIC
GVWR Class: Class H
GVWR Range: 9,001 - 10,000 Pounds
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: W31
Vehicle Line: F-350
Series: Styleside
Body Type: CREW
Vehicle Type: Truck/SUV
Engine Type - 8th Position
VIN Code: F
Engine: 7.3 L
Cylinders: 8
Fuel: Diesel
Model Year - 10th Position
VIN Code: Y
Model Year: 2000
Assembly Plant - 11th Position
VIN Code: E
Assembly Plant: KENTUCKY TRUCK: JEFFERSON COUNTY, KY
Production Sequence Number - 12th - 17th
VIN Code: C81024
Prod Sequence Number C81024
YES
Almostdunfukinwidit
Here is where i got the info https://www.fleet.ford.com/maintenan...ls/default.asp
VIN Number Decoder offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
Old 07-29-2009, 06:56 AM
Wow that was fast guys. Well where do i get the info if i am running PMRs and what rear end is under it? It also has a rear swaybar IDT my old truck had this.
Old 07-29-2009, 07:10 AM
Almostdunfukinwidit
The rear end is a sterling 10.5. As far as PMR's you would have to check the inspection hole yourself. And the swaybar in the rear tells me the truck has the camper package
Old 07-29-2009, 07:11 AM
Subscribing so I can do this later.
