making a 2wd trans a 4wd trans - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-14-2007, 09:47 PM Thread Starter
hi guys
i have found a truck thats 4wd that needs a trans thats a good deal . an have found a 2wd trans with low miles . can u make a a 2wd trans fit a 4wd
? if so what all has to be done ? is it just changing the tail shaft ? or is it to were u have to get inside the trans an take it all apart ? any info would be great .
thanks chad
midniterider is offline
post #2 of 4 Old 02-14-2007, 10:12 PM
dustindiesel's Avatar
the older trucks u jus chg the tailshaft and put a transfer case on it..i wouldnt think anything internally would be different but im not sure about the tcm or other sensors on the newer trucks
2003 psd 6.0
red crewcab
16" suspension lift, 48" michelin xml's on 20x10 black rockstars, 6000k hid's, crossover steering, zoodad mod, ccv mod, modified up pipe to delete egr cooler,high idle mod, mbrp 3.5 downpipe, train horns(also on remote), diamond plate tool box, recon smoked cablights, Code670 alarm/remote start,100w reverse lights, oil-based underbody paint
**soon to purchase SCT rockwell 2.5 ton frt/rear
-8,520lbs with me in it
dustindiesel is offline
post #3 of 4 Old 02-14-2007, 10:32 PM Thread Starter
the trans ai am talking about is the fr100 automatic
post #4 of 4 Old 02-14-2007, 10:45 PM
google search advance adapters and see what they say..they do all sorts of mis-matched combos and prob could look it up 4 u
2003 psd 6.0
red crewcab
