DANA 80 Differential - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-28-2009, 11:40 AM Thread Starter
hello everyone,
On DANA 80 differential in order to set the pinion depth by shimming, do you need to remove the pinion bearing? In another word do you have to take the pinion bearing out each time you shim the pinion to achieve required pinion depth? If the answer is yes, does it require hydraulic press to remove and put the bearing back each time you shim it? I am planning on changing my gear ratio to 3.73 from 3.54 but want to gather as much info to see whether I can do it on my own or take it to a shop.
Thanks for the info,
Isa
1999 FORD F 350 CREW CAB, LONG BED DUALLY
7.3 PSD, AUTO, 78,500 miles.
AIS Severe duty intake system
Rear Gear ratio 3.73
Isspro Trans, Boost, Pyro, gaugae [A Pillar]
MBRP 4 turbo back exhaust
Everthing else is stock.
2009 VW JETTA TDI 6 spd manual.
isa540 is offline
post #2 of 2 Old 07-28-2009, 12:14 PM
DBM
you can get a second bearing (or use the old one if you were planning to replace them) and use a die grinder and machine it just enough to slide on and off the pinion till you get the shims figured out then press on the good bearing...
"have not shot the gun yet but will next week when we see the mother in law." Quoted from a gun forum!
2004 CC 6.0 4x4 lariat
MODS: BPD Remote Oil Cooler, MTW Stage 1, GoGo Diesel Direct Drive Soleniod, Swamps 58v FICM, ARP's, Sinister EGR Delete, SCT XCAL3 w/DJ's Looney, Dfuser coolant filter, 4" straight pipe, Ranch Hand, Tuff-Country Level Kit, Isspro Boost/Trans Temp/Fuel Pressure/Pyro gauges, Edge Insight CTS...
DBM is offline
