second hand excursion 01 - Ford Powerstroke Diesel Forum
Old 07-28-2009, 10:03 AM
hello guys
i joined this forum because i want to ask some things about
a second hand ford excursion that would like to buy .
it has the 7.3 diesel engine and is from 2001 , has about 100.000 miles.
What are important things to check to look for when i go check the car .
this is the add for the car :
904.10 FORD EXCURSION 7.3 TD - 4X4 - FULL OPTION - LICHTE VRACHT
feel free to add your comments as i dont have many knowledge about ford's
but one thing i love already is the sound
Old 07-28-2009, 10:11 AM
7.3 is a good reliable strong motor! I am very happy with mine.
As for what all to look for, IDK, just the norm. If it runs good and doesn't leak oil, she is probably in good shape.
I'm sure there will be some more guys chime in here in a min with more details on what to look for. Good luck to you.
Old 07-28-2009, 10:25 AM
ok thanks man , some on this forum said to ask to current owner if the tranny has been replaced .
Old 07-28-2009, 10:35 AM
Cynic
Ask for maintenance records.
Pull the intake tube and check for dirt.
Pull the intake tube off the turbo and check the compressor fins for damage as well as play in the shaft. IN-OUT play should be minimal with no SIDE-SIDE play.
Have the truck checked out on a scanner for any codes. Have a buzz test and cylinder contrib/balance done while the engine is hot. During this time monitor the datastream PID's. Have the mechanic verify that ICP/IPR values are in range.
Have the hubs checked out as well as the shafts, TC, and rear axle.
Old 07-28-2009, 11:35 AM
Holy....... Dirk is very thorough when it comes to stuff.
Check out this link, it is a bunch of guys with 7.3s and mileage.
Mileage Report
As for the tranny.....lots of different things to take into account there, did the truck pull a trailer most its life? Oversized tires? Programmer?......etc.
My parents have 120k on their excursion 7.3L, no tranny issues. Still runs great.
Old 07-28-2009, 11:37 AM
I think there's a page on here "what to check on a 7.3 PSD" or something like that... one of us who is more computer literate than I could post it maybe?
Trannys are common problems... mine went out 10K miles after I got it.
Old 07-28-2009, 01:17 PM
it seems there are some confusing torque numbers around for the 7.3
7.3 L vs 6.0 L vs 6.4 L : Power Stroke Comparison
here they state 525
and this guy at youtube talks about only 314
YouTube - 7.3 HIGH PERFORMANCE MODS 1 OF 3
so who is right , mayeb two or more versions exist , and what type is in the excursion ?
thanks already for all the answers so far
Old 07-28-2009, 01:20 PM
Almostdunfukinwidit
Forget everything you saw in the powerstrokehelp youtube videos. That guy doesn't know his *** from a hole in the ground
Old 07-28-2009, 01:23 PM
Cynic
here they state 525
The powerstrokehelp guy is a complete tool and should never speak about powerstroke performance. I will rarely speak badly about someone, but geez! That guy just makes me furious. He has been the subject of many heated threads and has had a personal invite to join this site as well as a few others to explain himself.
As far as the power ratings, they changed over the years due to newer programming.
Old 07-28-2009, 02:42 PM
Govy Magnet
I had mine checked out by my local dealership. Just go and ask the diesel tech to do a once over and scan. When I got mine it had an up-pipe leak (notorious on the 7.3's) so I had the other Ford dealership replace them before I made the purchase. The scan and stuff normally runs around 75 bucks, but worth it in the long run. As for the towing etc, easy way to tell if he towed a lot of heavy heavy stuff is either a trailer brake controller, or if the front brake rotors have not been replaced recently, look for small hairline cracks, not deep but noticable, those are definate signs of towing a lot.
~Phil
