Any way to tell if I have a "chip"? - Ford Powerstroke Diesel Forum
Old 07-26-2009, 07:20 PM
I have an 01' PSD X. The boost numbers I'm seeing reported on stock systems seem low to me. As far as I know my truck is not chipped - although it could be - I'm the 3rd owner. Is there a way to tell? Do I need to pull the ECU and look at the board? Is there an easier way to check?
I know that in 01' some custom chips were soldered directly into place on Audi's - I know I had one - could this be the case with my PSD? I've seen 28psi when pushing it hard. Not often, just a few times.
Old 07-26-2009, 07:30 PM
Shade tree mechanic
Any black smoke? I'd pull the PCM and take a look(if it is a chip and not a programmer)
Old 07-26-2009, 07:52 PM
I run on veg - but even on diesel I've never seen coal out of this baby no matter how hard I ride it.
Old 07-26-2009, 07:58 PM
Send a message via AIM to SUPER60omni
Its got somthing.... 28 psi is not stock. My truck ran 15-17 stock. With my edge i have seen 30 on a cold night on the highway while romping it hard.
Old 07-26-2009, 08:01 PM
I'm going to need to watch the gauges a little better. I really would rather not have to pull the PCB to look - I hate working up behind the fuse box - there is no worse place to wedge yourself into in those trucks and I'm not a big guy - I can only imagine the 6'4" 250lb guy trying to get in there...
ADMIN AND TECH
definitly has something in there , 15-17 is generally factory specs, at 28 lbs , thats gotta be at least an 80 or 100 horse setting, probably has a programmer in it
Old 07-26-2009, 08:14 PM
I drive like a snowbird most times as I have precious cargo aboard. Again I've only seen it once or twice and it was flooring it. Again I'll need to watch the gauges. If I had a programmer where would it be? Under the steering column?
Old 07-27-2009, 06:11 AM
Isnt there the possibility that the PCM itself has been flashed as well? You very well may find nothing anywhere, and end up having a custom flashed PCM....
Old 07-27-2009, 06:21 PM
i have seen 23psi out of my truck and i has no chip. It will blow a little smoke every nown then when i get on it
