rwhp limit - Ford Powerstroke Diesel Forum
post #1 of 21 Old 02-14-2007, 11:17 AM Thread Starter
rwhp limit
does anyone know what the limit for a 7.3L rwhp and tq
Randle1 is offline
post #2 of 21 Old 02-14-2007, 12:23 PM
International Threat
Marty's Avatar
Biggest limitation is your wallet.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #3 of 21 Old 02-14-2007, 12:25 PM
Marty's Avatar
I guess that doesn't answer your question. Your big HP 7.3 guys are in the high 700's with nitrous. There are very few. Over 15k invested in mods on a motor that could blow any minute, and would be lucky to run for 100,000 miles.
Any better?
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #4 of 21 Old 02-14-2007, 12:28 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
Right now the bar seems to be around 700 hp with a lot of work. It will probably get higher and higher.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #5 of 21 Old 02-14-2007, 12:48 PM
lilredpowerstroke's Avatar
If youre talking about without building the bottom end it depends on what year engine. 94-2000 will stand about 500 rwhp 2001-2003 will take 400 rwhp before breaking a rod and puttin a window in the block.
T.J.
2003 F-350 dually 6.0
Centennial Edition
Straight exhaust 34x10.50 Swampers on Black Rock Stars
Been a member longer than most of the moderators
Thats why I said most Tiff
Think you can trust the government? Ask an American Indian!
My old truck in action
lilredpowerstroke is offline
post #6 of 21 Old 02-14-2007, 05:03 PM
Stroked95's Avatar
If you can call it a powerstroke I think the limit is 1500hp and somewhere in the nieghborhood of 2000lb ft. It was the v-pumped powerstroke that had about $100k in the motor I guess it has been clarified that it was a v-pump, not a p-pump, off of a mack truck v8 diesel. So it's an easy 1500hp provided you have $100k burning a whole in your pocket
1995 Reg Cab F350
totaldieselperformance.comWildman Tuning
terminatorengineering.com Terminator Nation
wideopenperformance
Stroked95 is offline
post #7 of 21 Old 02-14-2007, 08:51 PM
Is it even worth it???
ABOBB's Avatar
Actually solid rumors around here put the price closer to $150K. It pushed 1500 hp, and was in the 1800 tq range, at the flywheel. Totally non streetable set up. Mechanically injected, two huge turbos, and over 100 psi boost.
Here a some pictures:
Hood off pictures from extreme sports photos on webshots
Here is a video:
Video - Modified DHRA Diesel Class Saturday @ Scheids Extravaganza 2006
ABOBB
Aaron A. Bobb
2002 F-250 SD ExCab, Short Bed, PSD, Auto trans, 4X4
Custom tuned 6 position Chip
Whelen CSP690 Strobe Kit (Installed @ Feb Indy Strokers Rally... Thanks Adam), ZooDad Mod
COMING ATTRACTIONS:
Heated Side Mirrors, Owner Built Rear Airbag System
Owner Built Front Bumper, Owner Built Tymar Intake
Owner Built Custom Exhaust, Rear Roll Pan?
ABOBB is offline
post #8 of 21 Old 02-14-2007, 09:08 PM
dustindiesel's Avatar
that baby is bad..wish i had the money
2003 psd 6.0
red crewcab
16" suspension lift, 48" michelin xml's on 20x10 black rockstars, 6000k hid's, crossover steering, zoodad mod, ccv mod, modified up pipe to delete egr cooler,high idle mod, mbrp 3.5 downpipe, train horns(also on remote), diamond plate tool box, recon smoked cablights, Code670 alarm/remote start,100w reverse lights, oil-based underbody paint
**soon to purchase SCT rockwell 2.5 ton frt/rear
-8,520lbs with me in it
dustindiesel is offline
post #9 of 21 Old 02-14-2007, 09:20 PM
Stroked95's Avatar
It has four tires looks streetable to me $100k or $150k either way it's a @#$% load of money to spend to make that kinda power with a "powerstroke."
I think Zane from wideopenperformance runs at or over 100psi with his twin turboed powerstroke.
1995 Reg Cab F350
wideopenperformance
post #10 of 21 Old 02-14-2007, 09:26 PM
hugeredford's Avatar
looks like you can hardly call it a powerstroke
1995 IDI f350 4x4 8 inch lift new paint stacks:whistle:
It's not leaking oil, it's sweating horsepower.
2005 VW beetle diesel 36000 miles 50 mpg
you should all buy one
2005 f350 6.0 cc lb 4x4 drw lariat. EGR welded on both ends and valve removed--------MONEY PIT
hugeredford is offline
