Leveling kit problems - Ford Powerstroke Diesel Forum
Old 07-24-2009, 12:25 PM
99-04 Ford F250/F350 Super Duty 2.8" Leveling Lift Kit:eBay Motors (item 230352341956 end time Jul-27-09 19:04:43 PDT)
I bought this on ebay because it was a cheap quick leveling kit. But I am not seeing how it will work with my early 99. The pin wont go anywhere?
Old 07-24-2009, 12:47 PM
Bump. Anyone?
Old 07-24-2009, 04:52 PM
it bolts to your stock leaf pack with the new longer center pins
Old 07-24-2009, 06:38 PM
did you get the square U bolts? I called that guy on ebay. I am looking for a kit. early 99(i have one) has square not semi round u bolts. Needs to match the top bracket.
if not, O'rieily auto has em? you will need thread size and the length of those but tell em square
Old 07-27-2009, 09:33 AM
what else do you need for this kit? pitman? new trackbar? or that's just it? How thick and long are these leafs? i want to make one, it's too expensive to buy it and send it from the states.
Thanks guys.
arriero
Old 07-27-2009, 10:12 AM
most of the time nothing, just install it with the correct U bolts.
Old 07-27-2009, 11:21 AM
I sure hope that he used spring steel and not flat bar...
Old 07-27-2009, 11:26 AM
yep!!!!!!!!!!!
Old 07-27-2009, 12:18 PM
Thats soooo flat bar. Good luck with them blocks for yer front axle....
