fpr mod? - Ford Powerstroke Diesel Forum
Old 07-23-2009, 11:50 AM
fpr mod?
I am going to do the fpr mod. I dont have a gauge for it yet.
Is their an amount of shim I can do thats going to help but be with in the safe range of pressure with out the gauge to accurately tell me?
I read on one thread a guy used a 4mm allen head bolt cut it short and ground the head to .075 for a thickness and inserted the threads into the spring a bit. Not much to bottom out but just enough to hold it straight?
Old 07-23-2009, 03:14 PM
Look in the tech threads. Dont do this mod until you have a fuel pressure gauge. Youll thank me later.
Old 07-23-2009, 03:43 PM
can i hook a gauge to the drain valve as on a thread i saw? he hooked it up to that andopene the valve. When he got it where it was needed he removed the gauge but close the valve?
Old 07-23-2009, 04:34 PM
the tech thread was it for gauge install? i did not see one for the shim (fpr mod)
thx
