power steering fluid change - Ford Powerstroke Diesel Forum
Old 07-23-2009, 10:42 AM
Whats the trick if any, in draining the power steering system?
there is a small cooler on the drivers side at the bottom of the radiator, whats that for?
thx
Old 07-23-2009, 08:17 PM
jcs jcs is offline
You can pull of the return hose stick it in a bucket and while someone turns the wheel lock to lock add fluid to the resivoir the cooler i think you are refering to is the power steering cooler
Old 07-23-2009, 08:19 PM
^^^^ this is what I did. I put in synthetic ATF. Seems much quieter.
Old 07-24-2009, 12:42 AM
OperationSmile.org
I gotta do this soon.
Old 07-24-2009, 11:33 AM
I am that hot
I pulled that hose and did just that. Got myself a huge funnel and mobil1 synthetic fluid and went to town. I put 4 quarts through it, now the little vent hole in the ps cap lets out the smell of tranny fluid, smells like poo but its ok. I like knowing that the fluid is new.
Old 07-25-2009, 02:52 PM
turn the wheel lock to lock and add fluid? Is the motor running or off?
i would of thought that running with the cap off would shoot fluid out?
Old 08-05-2009, 02:02 PM
con u guys put pictures? i'm planning to change the steering oil soon. Thanks
arriero
Old 08-06-2009, 05:34 AM
Powerstroke Junkie
Don't need pics, just follow the return hose from the brake booster and pull it and place in a bucket as already said. Yes the motor has to be running, how else does the pump , pump the old fluid out. 3 quarts should be enough, you will see the change in fluid color, and smell, lol!!! Synthetic ATF makes a big difference at idle and in the cold winter months.
NCH
Old 08-06-2009, 05:55 AM
BOSS LEVEL
subscribed
Old 08-06-2009, 06:56 AM
NCH - ATF is ok in there? no need for power steering fluid?
I was reading about this on the benz forum and they also suggest ATF
