2001 f350 wont start..
![]() hey guys my gf calls me mid day and said the truck wont start. so i get home and the truck will turn over but wont fire.. i tried some wd40 in the intake and nothing.. also i can hear the injectors clicking.. do u think it could be a cam sensor? i dont know what else it could be.. ![]() |
If you here the injectors then it sounds like a fuel pump. And NEVER spray anything in the truck to try and start it as you can have a run away.
![]() i have been searching and reading but had to make a thread lol.. this is my tow vechicle and i need to tow my trailer thur so i hope it get it sorted by then..
truck has 103k on it
well tonight were gonna try to run a few test and see whats going on..
If you spray a little starting fuid then you will be fine but to much and your truck will see an early grave. Do you have a scan tool that you can see if you are picking up at rpm reading. And even with a cam sensor bad it will start. If you want to spary a small about of starting fuid this works the best SMALL AMOUNT and if it dont start a little more and a little more till it just starts cuz to much and the thing will keep on running, but if you get it to start have someone inside to see if the rpms go up on the dash.
do you get a wait to start light? if not, the PCM is not getting power, and you have a blown fuse. more than likely it the fuel bowl heater on the back of the bowl. remove the harness plug from it and let it hang there, replace the fuse and it should fire up.
if you get a WTS light, check to see if you hear the Fuel pump running when key is in on position. if it runs, then it probably is your CPS. |
ok guys .. i DO have a wait to start light.. i tried some wd40 and still would not start.. when i turn the truck over the rpms do move on the gauges .. so i am leaning towards the sensor i hope... im waiting to get one to try that out, i appreciate all the help and keep giving me ideas guys
quick update !!!!
just changed the cam postioning sensor and the truck will still not start !!! also tryed a lil more wd40 and still nothing.. i tried A LIL either and the truck turned over faster but would not fire.. any ideas guys? PLEASE HELP |
Out of curiosity,what kind of voltage does your batteries have?Are you above 11volts?
