4R100 and ATF question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-22-2009, 04:16 PM Thread Starter
E'sStrokr01's Avatar
Question 4R100 and ATF question
So, I just bought my first PSD. It's an 01' SuperDuty Lariat. I love the truck btw.
Anyway, I just checked the fluid level and it was running warm while in neutral, and on level ground. I pulled the stick and it was just right at the lowest warm level. I figured I would add some ATF, so I went to my local Wal-Mart and bought some Dexron III
My question is:
Is it alright to just top it off with the good Dexron III, even though I have no knowledge on the history of this transmission? I'm thinking this transmission could have been redone, or replaced already because I have 198,xxx miles on the truck. I just bought it and I have no clue on the truck's history.
I really don't wanna flush the tranny fluid or really even change it for that matter either. It looks clean to start with and it runs fine, so I don't wanna mess with it. I don't want to run it low either, so is it okay just to add a quart or two of the Dexron III?????
My future plans are to add the Tru-Cool trans cooler (add-on to the current cooler). If I do this how much more tranny fluid would it most likely take? And would it be alright just to top it off then too? (Once I get the new cooler installed)???
Thanks
E'sStrokr01 is offline
post #2 of 7 Old 07-22-2009, 07:38 PM
billelf123's Avatar
I would refer to your owners manual for the correct transmission fluid type for the 4R100. Pretty sure you should be running Mercon only, putting in just any trans fluid will most likely damage your tranny.
If you just drain the tranny pan and change the filter only I believe a top off is 6-7 quarts. If you are flushing all trans fluid with an air hose by way of the cooler lines a complete refill is 17 quarts.
I am sure the local auto parts guy will tell you different but most guys on this site have forgotten more than they will ever know! DONT USE JUST ANY ATF!!!
Bill
2003
F250 Superduty XLT:
7.3L Powerstroke
TS Performance 6 Position Flip Chip
Eighteen K Power Module
DFUSER MAP-Maximizer
Turbo Master Wastegate Controller
Borg Warner Compressor Wheel
FASS Fuel Pump
FASS Suction Tube
GDS FUEL PRESSURE SPRING
AIH Delete W/Boost Fitting
Sonnax Shift Kit
DIY Big Air Filter
4" Magnaflow Turbo Back SS Exhaust
AutoMeter Ultra-Lite Gauges
6" Suspension Lift
35" Tires
45 Auto
billelf123 is offline
post #3 of 7 Old 07-23-2009, 04:06 AM Thread Starter
Correct me if I'm wrong, but everything I've read so far is that either Mercron or Dexron, or better yet, the Mercron III and Dexron III are the same designate, and is labeled sometimes as Mercron/Dexron III. That's what I put in there. It said it was for Ford vehicles requiring Mercron, and Dexron III
Take a look at this:
What trans fluid and how much
post #4 of 7 Old 07-23-2009, 01:12 PM
Just add more of the proper fluid. Even the best flush will leave some of the old fluid in there.
When I added my tru-cool I also needed to add a surprising amount of atf to get it full. I happened to have a few quarts of mobile 1 synthetic atf on the shelf so I used it. Pretty sure it took almost three quarts.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
post #5 of 7 Old 07-25-2009, 07:55 AM
billelf123's Avatar
I read the same post! I think your response is accurate and you are on the right track. I used Coastal DEX/MERC in my truck and am comfortable with my choice. I was considering Amsoil or Royal Purple but was not ready to do a complete tranny flush.
Bill
2003
F250 Superduty XLT:
7.3L Powerstroke
FASS Fuel Pump
FASS Suction Tube
Sonnax Shift Kit
DIY Big Air Filter
6" Suspension Lift
35" Tires
45 Auto
post #6 of 7 Old 07-25-2009, 08:22 AM
boschert_72's Avatar
There is a fluid called dex/merc, it is dexron III/ mercon III. your 4r100 takes mercon V.
Merc III doesnt have the friction modifiers that Merc V.
Just run mercV and dont worry about the rest
'99.5 F-250 SD PSD CCLB 4X4
Terminator Engineering, aFe, Airdog, Aeromotive, Skyjacker, Pink Stallion, Toyo M/T's, Fuel Octane 20x12's, Garrett, Banks, Diamond Eye, TransGo, Rockford Fosgate, Pioneer, Dp Tuner F6 Live, Aeroforce, BD Diesel, '11 Bed, '10 Bumper,'11 Tailgate, '05 HD heads, HID's, KC's(HID), Home-Made Traction Bars, 4KW Gear Reduction Starter, Ya know.... The Usual.....
Your gunna have to climb over a smokin pile of brass to get my guns!!
boschert_72 is offline
post #7 of 7 Old 07-25-2009, 09:07 AM
billelf123's Avatar
I am going to have to disagree with you!
Follow the link below, I think this is a good source of information and although some believe Mercon V is ok I wouldnt use it in my 4R100 tranny!
Bill
2003
F250 Superduty XLT:
7.3L Powerstroke
FASS Fuel Pump
FASS Suction Tube
Sonnax Shift Kit
DIY Big Air Filter
6" Suspension Lift
35" Tires
45 Auto
