Originally Posted by dragracing_123
I got some problems my battery light comes on and stays on. But the battery voltage shows it to be way high in volts. I just bought new batteries and top alternator what else is there i can do or need to do to fix this ****???? Thanks if you know any information please post it
Do you have dual alternators? You either have a ground issue to one of your alternators or the voltage sensing wire is open(orange/light blue) if both of those are ok then your voltage regulator is bad which is in the alternator.
