AC question
truck Ac works fine for 10-20 min then starts to blow hot air
have u looked at the ac clutch washer shim mod. Father and I both did it last week and gained alot more cooling. His clutch was slipping bad. We both gained 15-20 degrees of cooler air. At 106 air temp last week it was priceless
When its not blowing cold, is the compressor on? If its off check the low side pressure with one of those cheap gauges from autozone. My guess is that after a bit the pressure gets too low and the switch cuts it off. This would tend to mean low Freon, but only a little.
THANKS FOR THE I N F O guys
clutch is located by the degas bottle. Should have a 8mm bolt in the center. turn truck and ac on to break bolt free. turn off truck/ac to remove clutch. washer is on the INSIDE of the clutch so remove carefully so u dont drop it. remove washer. reinstall in reverse order and check to make sure clutch engages and disengages with the engine running.
U should be using a digital temp gauge to get accurate and fast measurements before and after. |
I had a similiar issue, it turned out to be the lowside sensor was going bad. I could touch it and re-engage the clutch, so 15 dollars later my a/c works all the time. just something to check out.
[QUOTE=cchase;1309935]I had a similiar issue, it turned out to be the lowside sensor was going bad. I could touch it and re-engage the clutch, so 15 dollars later my a/c works all the time. just something to check .outQUOTE][/ I'll check that thanks |
